Pioneer HTD-510 System Logo
Posted on Sep 28, 2008
HOW TO PLAY DVD WITHOUT REMOTE
LOST REMOTE. UNABLE TO PLAY DVD. THE PLAYER WILL NOT GET PAST THE MENU. I HAVE TRIED DIFFERENT BUTTONS STILL WONT WORK ANY SUGGESTIONS.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 02, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
22263
Points
19
Try pressing stop while at the menu. then stop again. then hit play. that works for most dvd players
Sean Johnson
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on Nov 22, 2009
Sean Johnson
Contributor
Level 1:
New Friend:
Answers
8
Questions
0
Helped
22975
Points
12
Universal remote is the only thing i have found that will work... I dont know why the buttons on the DVD player it self will not work and that pisses me off...
Anonymous
Level 1:
New Friend:
  • Posted on Aug 10, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
22263
Points
Press stop then hit the previous scene button till its at the beggining of movie! Yaay!
  • Anonymous Feb 25, 2013
    I dont believe it! Thank you so much for the advice John, it worked!
2answers
Navigate DVD menu without remote
You can't navigate the DVD menu, without a remote control.
3helpful
How to get unit to play without remote
You can probably use the front panel buttons (STOP PLAY OPEN/CLOSE etc) manually, the only thing you cannot do without the remote is access certain DVD menus, including subtitles/language/special features etc. You can always obtain and use a universal remote for basic menu functions later on if necessary.
To play a DVD movie without the remote, simply load your preferred disc, wait for the player to finish reading its contents, then to skip copyright warnings and/or the 'play movie' menu screen, press STOP, then PLAY, or simply press PLAY button where 'play movie' (or whatever function) is highlighted in the menu. These buttons should be on the front of the main unit. Doing this should encourage the player to detect the appropriate title (the movie) and play it (basic playback operation may not be possible with some DVD releases due to the numerous interactive menus and title pages, such as film trailers).
If basic manual operation is not completely possible with some DVD titles, consider a universal remote for your player if you have either lost your original, or the player was purchased/received without one. Such remotes are relatively inexpensive to purchase, and are available just about everywhere.
1helpful
2answers
How do we access the DVD player's menu without a remote?We were given a Sylvania DVL 100A but it has no remote, and I need to get to the menu and turn on the SDH (Subtitles for Deaf and Hard of Hearing)....
You could try purchasing a universal remote. Many of them can access even the most specific functions, although it might be labeled differently on the remote (so if you don't see it on the remote, just play around and it might really be there. I've had my input control for a TV actually turn out to be the TV/VCR button on my universal remote). Make sure it's a universal remote with DVD controls, otherwise it might not have that function at all.
Other than that, there's nothing else I can think of, since most DVD players don't have any menu button(s) on the unit itself.
6helpful
2answers
How can you get a movie to start playing without the remote? I have lost mine and pressing the play button just goes to the menu which loops
After the movie loads and shows "play" highlighted. And only then,press the stop button and then press the play button and the movie should play...hope this helps.
2answers
Lost remote control. Cann I play dvd without it?
As long as you have a play button on you dvd player you shouldn't have any issues playing the main movie, you may not be able to navigate to different menu options from with on the dvd it's self.
You may want to look into obtaining a universal remote you can pick on up at your local electronics store and are fairly cheap.
2helpful
How to region free code for JBL DVD PLAYER CINEMA SOUND 3
The model number would be helpful as well. Below are a few universal process's for JBL dvd players. Not 100% guaranteed..
Give them a try, if they don't work then post the model number for further info.
PROCESS 1
1. Turn on player without disc and wait for "no disc"
2. Press OSD on remote control
3. Press 314159
4. Press 0 for region 0 (or 2 for region 2, etc.)
5. Turn off player with 'off'
6. Ready.
PROCESS 2
1) Open DVD tray
2) Press and hold "6" button on remote control.
3) Press "Menu/PBC" button. The current region code will be displayed on screen.
4) Keep pressing the "Menu/PBC" button until the preferred region code is selected (0,1,2,3,4,5,6).
5) Press and hold the "Angle" button for more than 2 seconds to save the region code. "Writing Region ID" will appear on screen.
PROCESS 3
Volume off
Slide Open
Press volume+ for 3 sec on remote
Then press Language on remote fast
Then choose 0 for region free
Press ok
Good luck , let me know if one of them work. Thank you for trying Fixya!
1helpful
Sound, no picture
My husband pressed the P-Scan button on the remote control a couple of times or something, and lo and behold we got the video back. Please try that on your set as well.
Hope that helps.
2helpful
Dead remote = no dvd access?
Try a RCA universal remote with an input button. Try the codes for Orion , Sansui and RCA. Access the menu by holding down both volume buttons on the front of the set. There is no access to the jacks on the front of the set without a remote. If all else fails get a RF Modulator. This will allow you to watch your dvd by using the antenna jack on the back of the set.
2answers
Plays CDs but not DVDs
I had the same problem, don't try to hard it won't solve the problem. Just buy a new cheap one and it even will read more formats.
2answers
Using DVD player without remote
yes when you get to the dvd menu press play
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
