Nokia 7610 Logo
bilal hashmi Posted on Nov 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Memorycard pasword remove - Nokia 7610
Anonymous
Level 3:
  • Master 380 Answers
  • Posted on Dec 13, 2011
Anonymous
Master
Level 3:
Answers
380
Questions
0
Helped
102621
Points
1118
. *#4720# -Activate Half Rate Codec - Your phone uses a lower quality sound but you should gain approx 30% more Talk Time.
*#4720# -Deactivate Half Rate Codec.
3. *#0000# -Displays your phones software version, 1st Line : Software Version, 2nd Line : Software Release Date, 3rd Line : Compression Type.
4. *#9999# -Phones software version if *#0000# does not work.
5. *#06# -For checking the International Mobile Equipment Identity (IMEI Number)
6. #pw+1234567890+1# -Provider Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
7. #pw+1234567890+2# -Network Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
8. #pw+1234567890+3# -Country Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols)
9. #pw+1234567890+4# -SIM Card Lock Status. (use the "*" button to obtain the "p,w" and "+" symbols).
10. *#147# -(vodafone) this lets you know who called you last.
11. *#1471# -Last call (Only vodofone).
12. *#21# -Allows you to check the number that "All Calls" are diverted to.
13. *#2640# -Displays security code in use
14. *#30# -Lets you see the private number.
15. *#43# -Allows you to check the "Call Waiting" status of your phone.
16. *#61# -Allows you to check the number that "On No Reply" calls are diverted to.
17. *#62# -Allows you to check the number that "Divert If Unreachable (no service)" calls are diverted to.
18. *#67# -Allows you to check the number that "On Busy Calls" are diverted to.
19. *#67705646# -Removes operator logo on 3310 & 3330
20. *#73# -Reset phone timers and game scores.
21. *#746025625# -Displays the SIM Clock status, if your phone supports this power saving feature "SIM Clock Stop Allowed", it means you will get the best standby time possible.
22. *#7760# -Manufactures code.
23. *#7780# -Restore factory settings.
24. *#8110# -Software version for the nokia 8110.
25. *#92702689# -Displays - 1.Serial Number, 2.Date Made, 3.Purchase Date, 4.Date of last repair (0000 for no repairs), 5.Transfer User Data. To exit this mode you need to switch your phone off then on again.
26. *#94870345123456789# -Deactivate the PWM-Mem.
27. **21*number# -Turn on "All Calls" diverting to the phone number entered.
28. **61*number# -Turn on "No Reply" diverting to the phone number entered.
29. **67*number# -Turn on "On Busy" diverting to the phone number entered.
30. 12345 This is the default security phone lock code.
3helpful
How to raset code of qmobile
I have forgot my Qmobile e786 pasword want to remove my pasword and put new one what to do
Apr 12, 2013 • Cell Phones
5helpful
Nokia 2690, i forgot my memory card passwoard.
for unlocking to the nokia cellphone go to the settings next to the application [or] organisation right click in the memorycard option and select the delete password option enter the default password to remove the password from your memorycard..............
THANKS.
2answers
I have forget my memory cards pasword. How i can recover or remove it.
formatting is best for ur mobile momery card
bcoz when you delete something that is not erased thoroughly.
it can be experienced by using tuneup utilities in computers.
so formatting is necessary, so use these steps
*#7370# for reset settings
*#7780# for soft formatting
if you want complete format turn off phone,charge fully. then press green button, * button, no. 3 button, lastly I/O(power)button simultaneously.
your phone will be formatted in 3 mins approx.
Enter Default lock code is 12345.
2answers
Unlock memorycard password
MEMORY CARD PASSWORD.
you can use this link to Know about password memory.
(wiki.answers.com/Q/How_do_you_remove_micro_sd_password).
Take care.
3helpful
How to remove microsd memorycard password
The way is open your memory card from your phone and insert another phone which also support micro sd memory card. when you insert that then you will see memory card lock unlock memory card. first cancel that and Enter the tools option and go to memory card option. try to format memory card. if format memory card then from your memory remove password. thanks
1helpful
To remove memorycard password
THIS WILL MAKE YOU LOOSE ALL FILES!!!
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
Well when i put the memory duo stick in the game says there no memory card
Try to turn off the consoles a few times. When the message pops up again, try to remove the memorycard into slot B.
When this also failed, than you bought a third party memorycard. Third party memorycards are not licensed by Nintendo and they can easily get corrupted.
Power on problem
try removing the memorycard first if there's any..then try switching on.when it turn on..then there's a malware in the memorycard..try formatting it using a computer.
2answers
Memorycard locked
you will need to take the card and have them remove the code for you.
Top Nokia Cell Phones Experts
Kolbrun...
Muhammad Irshad...
Muhammad Irshad...
