Battery is charged but won't stay on
SOURCE: Stylus 7010 keeps shutting off battery fully
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may require professional repair.
SOURCE: My camera won't charge, and
If you can't neither charge the battery through USB nor the wall charger, I would advise to first replace the battery. If that does not help, it will be difficult to tell if it's worth repairing or replacing the camera.
SOURCE: Camera was low on battery.
1. Check if the battery is positioned and seated well in the camera.
2. If OK, and problems persists, exchange the battery and recheck.
3. If that does not help, your camera needs probably to be repaired.
