Question about Behringer XENYX 2442FX Mixer
I want a labelled diagram of behringer 2442fx mixer
Xenyx behringer mixer version 1.0 labelled diagram
  • Behringer Master
  • 5,603 Answers
Here: http://elektrotanya.com/behringer_ub2442fx-pro_sm.pdf/download.html
Scroll down to "get manual" and click to download. IGNORE other download links.
Posted on Dec 09, 2011
6ya staff
SOURCE:
I need driver update to connect with pre sonus artist one software
If you use the Behringer ASIO drivers (available from their web site) it will connect just fine, you should also be able to use the sound card drivers that came with the computer as they should pick up on the mixer (assuming it is a USB version) but you do not say if you have a Mac, PC or what operating system you are running so it is impossible to be precise
Mar 15, 2016 | Behringer XENyX 1204 XENyX 1204 12 Channel...
My behringer xenyx 802 premium 8-input mixer worked fine for 1 day but now it sounds watery and behringer support was no help at all
Sounds like it may have failed. Yes, it is likely that it needs to be returned. Another option is to unplug all inputs and outputs. Plug in ONE device into the board, and use the headphone jack on the board. Does it sound the same? Just basic troubleshooting may help.
Oct 02, 2012 | Behringer Xenyx 802 8-input 2-bus Mixer W/...
How to connect a Behringer XENYX 2442FX Mixer to a laptop
you need a cable with two A3F  XLR s going to a 1/8" stereo phone plug, male. plug the XLRs into the Main out L&R on the mixer. plug the 1/8" into the LINE Input on the laptop. You should be able to get the cable from any music store,or Radio Shack. below is a link to the manual,in case you don't have one. Good Luck!
http://www.behringer.com/assets/1622FX_P0557_M_EN.pdf
Aug 30, 2011 | Behringer XENYX 2442FX Mixer
Looking for a manual
Here:
The 2442 is just an extended version of the 1622FX. The manual covers the whole series.
Aug 07, 2011 | Behringer XENYX 2442FX Mixer
My Behringer Xenyx 2442Fx does not get power.I have checked the power cable also.Kindly help me out
The switching power supply has probably failed. See if you can get a number off the power supply board like SPS400 or similar. Unless you are electronically adept this is lkely NOT a DIY repair.
Jul 26, 2011 | Behringer XENYX 2442FX Mixer
I need instalation diagram for tascam DR-1 to behringer 2442
We don't have any graphic means of diagramming. You also don't say if this is for recording or playing or both. Assuming it is both, your best way would be to get two 1/8 stereo cables that split into two RCA plugs. Go from the headphone out of the DR1 to the CD inout jacks on the mixer. Then with the second cable go from teh CD out jacks of the mixer to the line in of the DR1.
Mar 31, 2011 | Behringer XENYX 2442FX Mixer
Behringer xenyx 2442fx : I need to know the correct voltages out of power-supply. Mixer has been seen by a previous tech and now FX area and mixer level leds are off (I've been a user of this mixer...
You should find pwer supply voltages of +/- 15 volts going to most of the op-amps.
You should find 48 volts for the phantom power source.
You should find 5 volts for the FX DSP or any other logic circuits.
You should find a +12 volt.
Here is a manual close to your unit (yours is an expansion of it):
http://elektrotanya.com/behringer_xenyx-1222fx_v1000_dpm5m_ub-spsu2_sch.zip/download.html
Feb 13, 2011 | Behringer XENYX 2442FX Mixer
Behringer XENYX 2442FX Mixer Logo
508 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Chickenwatt
Level 1 Expert
Ric Weide
Ric Weide
Level 1 Expert
Are you a Behringer Music Expert? Answer questions, earn points and help others
