Canon PIXMA MP830 All-In-One InkJet Printer Logo
A
Anonymous Posted on Dec 15, 2017
Hi, please help me solve my problem.
The problem began with a message saying that I had to wait, that the printer was undergoing maintenance. After a while I rebooted and when I tried to start up my MP 830 program ... nothing happened. What gives? everything was running smooth a few minutes before. I had done several scans OK. Thanks for your help
Molade jide
Level 1:
New Friend:
  • Contributor 22 Answers
  • Posted on Dec 15, 2017
Molade jide
Contributor
Level 1:
New Friend:
Answers
22
Questions
0
Helped
8369
Points
59
Did it finish maintenance before you reboot?
5 Related Answers
Anonymous
  • Posted on Oct 12, 2008
SOURCE: error e5 in mp 145
change a new black cartridge. the problem wont come back again.
Remag1234
Robert Allocca
  • 387 Answers
  • Posted on May 17, 2009
SOURCE: canon mp 830 will not scan but will print
Uninstall the software and reinstall. Use an ethernet cable and try scanning. If that does not work then your scanner feature has a problem. Probably very expensive so I suggest you go to the Epson site and look under Clearance. New/Refurbished have a 1 year warranty, replacements are quick and free shipping both ways. A All-In-One is $45 shipped, the ink costs more than that. Check this website for CISS system which saves lots of money.
http://www.inkproducts.com/ink-store/
Anonymous
  • 64 Answers
  • Posted on Sep 24, 2009
SOURCE: Scanning error on mp 830 - code 5010. What is
Hi, did some research for you and this is what I found:
Dear Customer,
Thank you for your recent enquiry regarding your Canon product.
In response to your query, please be advised that the error code "5010" indicates there is a scanner error and the printer will require service.
If the printer was bought recently you can contact the dealer and check the replacement program.
If you are outside the replacement policy, please find below a list of authorized service centers for your device and some packaging instructions:
The following office peripheral products: A3 and portable printers which are still under warranty, Laser Beam Printers, PC/FC Copiers, Multifunctional Devices and Fax machines benefit from on-site service.
On-site service can be arranged by dialing 0870 400 2080, or by contacting
Canon Ireland Ltd (Fax, Multifunctional and PCFC Copiers)
Arena Road
Sandyford Industrial Estate
Dublin 18
Tel: 01 205 2400
Fax: 01 295 8141
Web: http://www.canon.ie
Anonymous
  • Posted on Oct 04, 2009
SOURCE: Canon pixma mp 190 won't scan / copy and printing works!
I also have a newly purchased MP 190 that prints but will not scan at all have also tried reinstalling software.
anyone help me?? :(
Anonymous
  • 2306 Answers
  • Posted on Oct 29, 2009
SOURCE: Canon MP 830 I replace purge unit
You may need a new printhead now, or you may have left a foam packing block inside the new purge unit.
I can't get my online pass to work says undergoing maintenance
the website is probably undergoing maintenance, and is currently not accepting any logins. you are not making a mistake. wait and try again later.
23helpful
2answers
PlayStation 3 Network error (80701A06) \r\n How To Fix It ?.. Please .. :(
As of now PSN is down and currently undergoing maintenance this April 21, 2011 at midnight. If you receive this message don't panic since there were lots of other PS3 user encountered this error message.
All you have to do is wait until maintenance is completed.
Regards.
2helpful
2answers
Ps3 erroe code (80710A06) i try to sign in then it comes up with this error code and says i have been signed out, i have checked online for solutions and found none please can you help me as this is...
All you have to do is wait a while until maintenance is completed.
Regards.
I keep get Error 80710A06 on my PlayStation3.
Regards.
3helpful
Ricoh SP C811DN error sc549
unplug printer, wait minute, plug in, should reset.
check Ricoh website to trouble shoot if does not reset.
2answers
Printer is not working.
Hi Surenderpdsi
It sounds as if the printer spooler needs re-starting.
This is the path to the printer spooler service,
Windows XP Path (category view)
Start – Control Panel – Performance and maintenance – Administrative tools – Services.
Windows Vista Path (category view)
Start – Control Panel – System and Maintenance – Administrative tool – Services.
Once in Services both XP and Vista are the same.
Look down the list till you find Printer Spooler.
Once found, right click your mouse on Print Spooler and select Properties.
In the properties box that open the service status should read “Started” if not click on start.
If it says the spooler is started click stop, wait till the spooler has stopped then click start.
This will re-start the spooler and should fix your problem.
Hope this helps,
MK Support.
4helpful
Printer keeps saying Please Wait
I was able to solve this problem with a hard reset:
- type Menu *2864
- display shows: maintenance
- type 01
- display shows Parameter Init" then "Maintenance"
- type Stop 99
All settings are lost!
Printer Won't Switch On
It looks like you did have the "replace waste ink pads" problem. If you still have this problem and want help in solving it, please post a new comment to this effect.
Brother MFC-210C stuck in "please wait maintenance"
Press menu then start mono (b/w) then 4x arrow-up-button. Machine will be in maintenance-mode: What error code does the display show off?
old marine
old marine
ZJ Limited
ZJ Limited
