Is there a code or do we just ground out the brake wire??
SOURCE: how do i bypass the parking brake switch in order for my video to play
DVD head units have one extra wire in their wiring harnesses, compared
to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is
the activation wire for the DVD feature. During the installation, the
instructions call for this wire to be tapped into the emergency brake
indicator light wire. The reason is this:
The e-brake indicator
light is what is called a "ground complete" circuit. That means that
the bulb always has power applied, but when you pull the brake, that
puts a ground to the wire and completes the circuit, allowing it to
illuminate. The head unit sees this ground, and activates the DVD
player.
In my Jensen unit, I simply ran this wire to a ground (I
used a screw near the fuse box), and I put a switch on the wire, so I
could break the ground contact at will. Jensen calls for a procedure to
activate DVD playback. In their instructions, they tell you to select
DVD from the option menu, and when the "lawyer screen" comes up (the
one warning you to park before you watch a movie), you release the
e-brake for 3-5 seconds, and then reapply it. To simulate that with the
switch I used, I leave the switch closed (activated), and select DVD.
Then I flip the switch "off" for 3-5 seconds, and flip it back "on".
This tricks the head unit into thinking I put the e-brake off for a few
seconds and then put it back on, and the movie will start. Then I can
drive away.
Basically, ground the wire that is used for DVD
activation, and put a switch inline on it. Then you can break and
reapply the ground in whatever manner is required by the manufacturer
of your head unit. If there is no off/on sequence with yours, as there
is with mine, simply ground the wire to a screw inside the dashboard
and you're done.
SOURCE: parking brake bypass
The best solution and what i did was just plug the parking brake to the ground cable of the reciever...
And works perfect...
SOURCE: park brake bypass via switch to ground
Just connect the Park brake to a possitive it doesnt have to be the park brake!
SOURCE: panasonic cq-vw100u e brake bypass code
All you have to do is ground the green wire and put a two way switch inbetween it...
SOURCE: Dual xdvd 8625 double din emergency brake bypass
you can ground it,then enter the code 26604 after u insert a dvd real dvd then press stop twice then enter the code it should work
my system has stopped playing sound. everythings shows as if it is playing, it just does not emit sound.
JensenVM9226BT how to bypass brake wire?
