2001 Ford Expedition Logo
Posted on Nov 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a spark plug wiring diagram for a 4.6l Triton V8. 2001
Clifford Beard
Level 3:
  • Ford Master 1,975 Answers
  • Posted on Nov 21, 2011
Clifford Beard
Ford Master
Level 3:
Answers
1975
Questions
13
Helped
1993478
Points
6937
Your shouldn't have any spark plug wires on your vehicle. There should be a coil on top of each spark plug. The firing order is 1 3 7 2 6 5 4 8 if that helps. I went back a year incase you had a late model 2000 but that 4.6 also has a coil on plug. If you do have spark plug wires, I don't think that's the original engine then.
1 Related Answer
Anonymous
  • 512 Answers
  • Posted on Jan 03, 2009
SOURCE: 2001 dodge ram 1500 v8 spark plug wire diagram
the firing order is 1 8 4 3 6 5 7 2 clockwise around the cap
1helpful
Interior light wiring diagram to suit Mitsubishi Triton Mj 1992 diesel dual cab 4WD
Hello Robert, These diagrams can be found at the link below.
When your on the opening page....
Click Wiring Diagrams
Year: 1992
Make: Mitsubishi
Model: Mighty Max (AKA Triton)
Engine: 2.4 or 3.0
System: Lighting
Sub system: Dome Lamp or your choice.
dome lamp 2-lgkuwp4aw4khkvxj1psb51j4-3-1.png dome lamp-lgkuwp4aw4khkvxj1psb51j4-3-2.png
http://bbbind.com/free_tsb.html
Need the spark plug firing order for a ford F250 Superduty 5.4 Triton engine
Check with your mechanic and he will be able to tell you. Just a hint don't take all the spark plug wires off the same time. Take one off and put a new one on in it's place. Saves a lot of headaches.
2answers
2002 Ford F250 5.4 liter Triton V8 spark plug replacement?
Use a spark plug socket to remove plugs and replace new ones.
Spark plug gap for 1997 mitsubishi trition 2.4 petrol ute
Spark plug gap does not effect the engine timing so it's not that critical. Thirty 5 (.035) should work just fine.
Otherwise consult a service manual fro your model or call a Mitsubishi service centre
mitsubishi triton service manual
Mitsubishi Triton L200 2006 2013 Workshop Manuals Factory Service Manuals
1helpful
Where do i locate the spark plugs on my 03 triton 4.6l and how do i remove
spark plugs are located under ignition coils on top of engine. You will need a spark plug socket size 5/8 and socket extension to remove. Coils have a 2 wire black connecter and a 7mm bolt to remove.
2helpful
Hi I'm after an ingition diagram for a 91 model Mitsubishi Triton ute. I have a no start problem and I'm unable to check the distributor module as I have no specifications or check procedure.
Free online repair manuals can be found at autozone.com. You just have to register and look around you will find wire diagrams in the manual.
Does the engine crank over but does not start or is it not turning over?
Are you getting any fire? You may check this by removing one spark plug and putting the plug wire on the plug. Then touch the end of the plug to ground, set it against the engine block or valve cover. Have someone turn the engine over while you watch the end of the plug to see if there is a spark. Remember do not hold the plug or wire because you will get shocked.
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
