VIEWSONIC 22' WONT TURN ON. HIT THE POWER SWITCH KNOW REPLY
SOURCE: hello viewsonic vx2235wm no power
The Viewsonic VX2235WM has a known issue with the power supply going out. The flashing power light or not turning on is the classic symptoms of this issue. Check out our web site at: www.ccl-la.com. We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: [email protected]
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
SOURCE: Viewsonic VX2235wm Horizontal Image Problem
Tricky one. Have you tried using different dispay resolutions from your Windows Display Control Panel?
ie 1200x1014, 1600x1400, etc.
When you say you used the manual adjust, do you mean the horizontal sync option?
Did you perform a Settings Recall?
And most monitors have a way of entering into an engineering "Factory Service Menu". Usually by depressing specific buttons while the monitor is OFF, and then pressing the power button while still holding the others. Then let all button go at once. From there, hit the normal button that you use for getting into the OSD. In the OSD, there's usually a new field with all kinds of cool new settings to play with. One of them being a soft reset. You'll have to search the net for how to enter into your Factory service menu.
Oh wait! I know!
If your picture has moved to the right, move yourself accordingly.
So that now you and your picture will be aligned properly.
He he he...
Kidding!
That one was from ViewSonic customer support.
SOURCE: ViewSonic VX2235WM turns on than screen goes blank
The problem is most likely the monitor itself. Hook up an old monitor (usually someone has an old monitor laying around) if the computer works with another monitor you'll know for sure.
Look at your monitor using a flash light at an angle, if you can see a picture in the background you have a bad inverter.
SOURCE: how to remove the base from the viewsonic vx2235wm
You have to remove the two snap-on plastic hinge covers to get to the base mounting screws.
SOURCE: instructions on how to disassemble and fix a Viewsonic VX2235WM
Picture tube is not major problem. It is the main board, having damaged capacitors, could be more then 1. Other components to look at is, high voltage tranisitor, which gives up in most cases. Most cases in my career, i found that monitor tubes are good, unless the are dropped. So resolder the main board and check out for the components i mentioned. Careful while repairing, it has high voltage, take all precaution while openining the panel. Unsrew all the screwsat the back, also the stand, take a flat screw driver and lever the panel from one end till you open all the 4 sides. Thanks, and don't giveup.
