Hook your X Box into the Receiver HDMI input with your HDMI cable and another HDMI cable from the HDMI out on the receiver to the HDMI input on your TV.
If this is your system; http://www1.epinions.com/specs/pr-NAD_T742_5_1_Channel_Home_Audio_Receiver It has two "digital optical" inputs for sound. The video doesn't need to pass through the receiver so, your HD components, box and Bluray player, should hook to TV directly then, providing your TV has digital optical out, you could run your audio out of the TV from a digital optical out, to receiver. This would allow you to select your video through your TV's menu and the sound would come through the receiver through the one input. You can pass your video through the receiver but, it doesn't have the best outputs to handle it. You also may notice lags beteween the audio and video if you go this route.
BD and DVR hooked up to the receiver and from the receiver to the TV right? If yes: Your receiver set to pass sound trough to the TV, if you want sound from the home theater setting has to be changed.
Do you have set-top-box or antenna-cable directly to TV? You have connected TV with received via HDMI, but that won't work in this direction - TV has HDMI INput only, not output. You can use HDMI to connect HDMI-out on DVD player for example to HDMI-in on receiver and HDMI-out of receiver to HDMI-in on TV. But to get sound from TV to the receiver, use spdif optical or coax cable if TV supports that - this way you will get surround sound. But also your connection via analog white/red RCA plugs should work, but only for stereo sound.
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI You need to connect receiver and TV through analog video terminals as above. Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Have both the AV cables and hdmi cables hooked up from the tv to the
ps3. On the TV Menu goto the av station which is different from the
HDMi station...From the ps3 menu screen gotot settings then to video
and audio and select hdmi then back to the tv menu and select the hdmi
station and the ps3 main menu should be seen and you are all set
Yes, the firmware on your hdtv box has an old firmware, I switched my old hdtv box with a newer one box and the problem was solved. It seems that it can't work if your hooking up with DVI to HDMI cable to your receiver to tv. Your hd box must have an HDMI out otherwise it causes problems. I also have rx-v661 and i finally hooked up everything HDMI to the receiver and then to the tv and it was having the problem you speak of. After I switched out the hd box for a newer one everthing worked fine.
If you have two optical inputs and two equipment (PS3 and HDVD) then you shouldnt have a problem at all. Just make sure you change the mode of the receiver to TV/SAT when you want to use the HDDVD. Your problem may be the video out put.
If i was you i would do the following:
1. Get rid of all your optical cables as you won't need it.
2. If your receiver support HDMI then by default HDMI will send both video and digital sound.
3. Plug the HDMI of the PS3 to the HDMI input of the receiver, plug the HDMI of the HDDVD player into the HDMI 2 of the receiver and plug 1 HDMI cable from the receiver to the tv/monitor you have.
That is the best set up so when you play PS3 you select dvd/ld and when you watch hddvd you select tv/sat.
However having said all that the fact that you have dvd/ld suggests you actually don't have HDMI at all on the receiver(...i just checked the specs of the receiver). Which means you will need to have 2 hdmi inputs for your tv and you will need to have the 2 optical connections.
