When you change your setting to nam 2 how do you unlock your phone
Go to the keypad, type #43574357* (this number should work) and select system info, and it will display your nam2 phone number on the first (top) row labeled "MDN." The last four numbers is your passcode.This solution ONLY works if you've accidentally set your phone to NAM2 (which means that you've reprogrammed your phone to a completely different phone number, and if you've set up a passcode, that too is changed). Once you've found out your new number and passcode, you are not yet finished, because your phone is still programmed to NAM2. To fix that, you must go to your "Phone settings" and find "NAM select." Then you select NAM1 (and your phone will restart again and prompt you with your OLD passcode, if you set up one). Your phone is now fully functioning again!
Panasonic CDMA Phone Service Center
