I try to take a picture and it wont let me and it says that my card is locked and it shows a locked picture in the corner where the battery picture is... I cant unlock my card I dont know how
Re: My SD card is locked and i cant get it unlocked
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
<p>Many times people
do not realize that a <span style="font-weight: bold;">SD card</span> can be <span style="font-weight: bold;">write protected </span>or locked. They
will <span style="font-weight: bold;">try to download pictures</span> or <span style="font-weight: bold;">make changes to the pictures </span>and the
<span style="font-weight: bold;">SD card will not allow</span> them to do it. The little lock feature on the
side of the card will <span style="font-weight: bold;">write protect the SD card</span> so that changes cannot
be made. You will need to <span style="font-weight: bold;">unlock the SD card</span> to be able to make the
changes that you want to make or download anything from it.<br />
<p><br />
<br />
<p><span style="font-weight: bold;">To allow the SD card
to be accessed</span> is a simple as sliding a small tab on the side of the
card to the <span style="font-weight: bold;">unlocked position</span>. Usually this means sliding the tab
towards the back of the card and away from the front of the card. The
card will have to be removed from the <span style="font-weight: bold;">camera</span> or <span style="font-weight: bold;">PC</span> to be able to do
this.<br />
<p><br />
<br />
<p>Here is a <span style="font-weight: bold;">picture
of an SD Card</span> and you can see the tab on the side of the card. It
clearly shows you what is the locked and unlocked positions on the
card.<br />
<p><br />
<br />
<p><img src="heatman101_2.jpg" /><br />
<br />
<p><br />
<br />
<p>This feature can
be very useful to make sure that you do not inadvertently <span style="font-weight: bold;">erase data
or pictures</span> from the card. If you have children viewing pictures on
the SD Card make sure to lock it before allowing them to play around
to make sure that they <span style="font-weight: bold;">do not erase your pictures</span>.<br />
<p><br />
<br />
<p>As you can see
this is a very good feature to have and it will be very useful to
you, but you do need to remember to unlock it before trying to make
changes to the card.<br />
Not sure if it will be this, but has the SD card got locked by accident? There is a little sliding button on the side of the card, which can be locked to protect the content. My camera shows the card as full if I accidentally lock the card. You can just slide it back again to unlock it. I never noticed the button was there until I accidentally knocked it while loading the card in and out of my PC to transfer the photos.
I am assuming that your camera uses and SD card to store the pictures.
If you remove the memory card from the camera, you should see a little slider on the side of the card that says "lock," it is easy to accidentally lock SD cards.
I have attached a picture to show you what a locked SD card looks like.\:
Here is another image showing the card in the unlocked position:
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
There is usually a switch on the side of most picture cards (I am guessing its an SD card) this is the lock switch. Try setting it to the 'Unlocked' position.
Good Luck!
it uses a SD card which has a lock & unlock button in the side.
try sliding it up to unlock, if it doesn't work then the card is no longer useful. u can give the card to the manufacturer if under warranty, usual takes a lot of time, or u can get a new card.
