Question about LG Flatron L1715S 17" LCD Monitor
LG flatron L1715s screen is black osd locked??
I attached this monitor to my pc, turned on and worked fine, i went into the menu button as screen seamed stretched, i clicked to reset settings, it then flicked off / went black, and seconds later came on with windows screen visible for only a few seconds and then goes black again, the only was i can get picture is by turning off anf back on, tried unplugging it, tried holding the menu button as ive seen ppl say makes the osd lock go on / off, this did nothing! any ideas what ive done and how to get it back on again? (my cousin said it had flashed up with osd locked) but havnt seen this myself as it too fast in going black!! please help.
  • LG Master
  • 27,725 Answers
This could relate back to your computer
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connections and are not faulty or just replace them they might be faulty
make sure all leads that are attached to your drives dvd\cd have secure dust free connections and are not faulty even the electical extensions
even something as small as an electrical fan and its lead can cause you problems or just replace them they could be faulty a computer needs all electrical power and data to continue through every working device and to have an end so any faulty leads will end up with a computer error
make sure your graphics card is securely seated with no dust built up or in the socket
if you remove your graphics check the socket to make sure its dust free
restart your computer then reinstall it this should activate found new hardware wizard
hope this helps you
Posted on Nov 25, 2011
  • Sarah Dec 04, 2011
    If this is the problem with the pc im guessing the old monitor wouldnt work either? correct me if im wrong tho? as ive reconnected the old monitor and that works fine, its since resetting the lcd monitor settings it went off.
  • 2,229 Answers
Your video settings may actually be out of range of the monitor.
Try starting the computer in safe mode. This will provide basic video without anything fancy. Reset the settings to a lower resolution from the display option in the control panel (or simply right-click on the desktop).
If the display works then, restart the computer and then try different settings from Windows, not the monitor itself.
Posted on Nov 24, 2011
  • 1 more comment
  • Sarah Nov 25, 2011
    Hi and thanks for your suggestion, just tried that now and in safe mode its set to lowest res and still nothing is displayed, ive set windows to the lowest res and same as before. any other suggestions? when i shine a light on the screne i can see the display so anyone know if i need to change the settings back and how i would do this as the monitor worked fine until i clicked to reset settings, this is when i went off so im presuming its the settings???
  • Art Ellison
    Art Ellison Nov 25, 2011
    Ahhh--that's the answer. Your backlight has gone bad. The LCD screens are backlit with a flourescent light. If that burns out, you get the effect that you described--you can see the image but only by shining a light on it.
    The good thing is that it can be repaired. If you feel like tackling it, you can change the tube (but you need to take it apart and get the part). If electronics repair isn't your thing, just have a computer shop do it for you.
    Can i just ask about the backlight if it has gone, would i get upon start up the normal bright blue windows page displayed on the monitor? as i get this for a few seconds when i turn it off and on again, il maby have to take to to a repair shop and ask them, Thanks for your advice so far.
6ya staff
SOURCE:
Flatron W1942TQ monitor has "OSD Locked" message
Press and hold menu button for a few seconds, pressing and holding, acts as a toggle. So if OSD LOCKED still appears, pressing again UNLOCKS.
Mar 25, 2011 | LG Flatron L1951S 19" LCD Flat Panel...
OSD Locked How do I unlock the monitor?
Hold the MENU button for 5 seconds, the 'OSD LOCKED' will appear, to unlock, hold MENU button for 5 seconds, the 'OSD UNLOCKED' will appear. It may not work on ALL LG LCD panels.
Please post back, otherwise check the owner manual.
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Sep 09, 2010 | LG 22" FLATRON LCD Monitor
MY LG FLATRON L1951S, THE OSD IS LOCKED. HOW CAN I UNLOCK IT.
On screen display is locked. Fix it by:
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Mar 14, 2010 | LG Flatron L1951S 19" LCD Flat Panel...
Message: OSD LOCKED'' when i press a button on my LG Flatron L1720
change all pressing keys..then press menu key 15 seconds for unlocked.
Jan 21, 2010 | LG 22" FLATRON LCD Monitor
I am using the LG Flatron L1715S 17" LCD Monitor as an external monitor for my lap top as the screen on my lap top is toast. What I cant figure out is how to size the screen to fit the proper dimensions of...
The FLATRON L1715S color LCD monitor with auto-synchronous support, plus it is PC and MAC compatible, has features like simple one button auto setup and is VESA DDC2B, DDC1, Plug and Play compatible.
use the 'Auto' adjust button on ur lcd..
howevr, if u want to configure using win xp/vista..right click on ur desktop->properties->settings->increase the 'screen resolution' to minimum: 640x350 or standard: 1152x864 or maximum: 1280x1024 @ 75Hz..
best is to seek professional advice of ur system admin/vendor....
Nov 05, 2009 | LG Flatron L1715S 17" LCD Monitor
FLATRON L192WS LG
hold de book buton 5 or 6 sek
Aug 10, 2008 | LG Flatron L1750S 17" LCD Monitor
OSD Locked
Press menu button for 5 seconds until the text "OSD Unlocked" appears on the screen.
Aug 28, 2007 | LG Flatron L1750S 17" LCD Monitor
Monitor displays "Controls Locked"
This is a "feature" they include to prevent accidental changes to the screen setup. You should be able to unlock the OSD by pushing the Menu button and the right arrow button together for about three seconds. The message "controls unlocked" should appear. Let us know if you have any other questions and please don't forget to rate the posting.
Jan 31, 2007 | LG Flatron L1715S 17" LCD Monitor
LG Flatron L1715S 17" LCD Monitor Logo
236 people viewed this question
Top LG Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
