Unfortunately, the F1E1 error indicates a EEPROM checksum problem with the control board. An internal check for the board gave a result that didn't match the one that is stored in the read-only memory. The only solution is to replace the electronic control board for the stove.
Please add a comment with the model number of the stove if you would like to know if this control board is still available and the price for it.
I understand the control panel is dim and hard to read, on your Frigidaire oven, model# FEB756CETF. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and set the clock. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
I understand you want to know what the EOC is on your Frigidaire range. The EOC is the electronic control board that is basically the brain of your appliance. It is typically located behind the control panel of your range. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
F2/E6 fault code implies a Cancel key drive line open. This means the key pad ribbon connector could be loose or dirty where it connects to the oven control board or a faulty oven control board.
Press Cancel. If the error code returns after 60 seconds, replace the key pad. If it continues to display F2/E6 after replacing the key pad, replace the oven control board. The parts can be ordered from Sears PartsDirect
NOTE: Disconnect the power supply from the oven before servicing.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate
your time and consideration if you leave some testimonial comment about
this answer.
F7 means Stuck Button - Function pad button stuck or
- Bad clock. Try to free stuck button or
- Replace Electronic Range Control (ERC).
Someone mention that intermittent F7 problems are usually caused by poor
connections. So I pulled the ribbon connector off the control board and
cleaned the copper connectors using a pink pencil eraser.
It's important that you don't skimp the disconnect test because there's a
big difference in price between the ERC and touch pad. So, you want to
be right on this one. Ok, after you do this test and determine which
part you need to replace, come and get it here.
this answer.
Hello there and thank you for choosing fixya On Magic Chef ranges, F1 usually indicated a defect in either the
keypad or the electronic control. If the error shows when the keypad is
disconnected from control, the problem is usually in the control. If the
error ceases with the keypad disconnected, the keypad is usually the
cause.
On some models the keypad and electronic control are 1 integral
part in which case the whole control assembly usually has to be replaced
to correct the problem.
ok i hope this is very helpful for you please post me a comment and i can help if you need assistance with parts support or disassembley ok Best regards Michael
Thanks for using FixYa. F1 error means that the control board (ERC) has gone bad and the electronic range control (ERC) should be replaced to resolve the issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks for using FixYa. Error F1 means that the control board (ERC) has gone bad and the electronic range control (ERC) should be replaced to resolve the issue. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Hi Thanks for using FixYa. Error F7
means that the function pad button is stuck or the clock has gone bad. If you
are unable to unstick the button then to resolve this issue you’ll have to
replace the electronic range control. Please do rate the solution
if the issue is resolved or post a comment for further assistance. Thanks Rylee
u may have a bad connection between that touchpad to the control board. some had 5yr parts warrantys on the parts depending on when u purchased it it may apply.. if not you probably neeed to replace that touchpad which they want allot for average price probably 200-400 for just that touchpad i know its ridicoulous but prob better than buying a new walloven.....u may need service but this is probably whut they will tell you.. hope this helps
