Stihl 101AV chainsaw diagrams, i need the parts diagram that shows all of the chain side of the saw. Any more diagrams of the saw would be appreciated, thanks Dave.
Hi try here good luck
http://www.stihlusa.com/manuals/instruction-manuals/
Steve
SOURCE: 0340 AV stihl chainsaw won't fire
Spray a little starter fluid down the carburator . It is starts then is is a fuel problem. Most likely a gummed up carburator. Remove and clean .
SOURCE: Stihl chainsaw
Hi
First remove the cover,air filter and the carburator.Then remove the gas tank cap and the fuel filter from inside of gas tank,at the end of fuel line.Take off the fuel line from the hole of the gas tank(at the top),replace the fuel line,put all back together and start the engine.
best regards savumihai71
SOURCE: where can I get manual for model 358.355061 craftsman chainsaw ?
Sears sells manuals for a reasonable cost; my last one was $7 US. Go to their website at sears.com and follow the links.
SOURCE: owners manual for a Stihl 034 AV Chain saw
Stihl Manuals
http://www.stihlusa.com/information/info_product2.html
For an IPL you must contact them.
HTH
Lou
SOURCE: Does the centrifical clutch on a Stihl 034 AV
I cannot find a manual for an 034 so I must make my best guess (yes, left handed thread). Most Stihl saws have inboard clutches. I am going to reply as though that is true. The drive sprocket does not require (if inboard clutch) clutch removal. It must be removed to access the actual clutch. I reply as though you want to actually remove the clutch itself.
Do this first:
R² Drive Link Inboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=YUbSIHMSSP8
The C-clips tend to fly when being removed. Please wear eye protection and exercise care.
Continue using this as a guide:
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
If I missed any part of your question you can reply below and I will clarify. Good Luck with your project. HTH
Lou
Testimonial: "To Lou, Thanks very much for the advice re clutch on Stihl 034AV. came off easily and I was especially pleased with your tip re using some rope"
