Vizio 42 in. LCD TV Logo
Anonymous Posted on Nov 25, 2011
Vizio LCD dark screen and picture is flickering flashing
Vizio LCD has a dark screen and the picture is flickering or flashing.
Anonymous
Level 2:
Sergeant:
  • Expert 302 Answers
  • Posted on Nov 26, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
302
Questions
0
Helped
91681
Points
594
Your back light inverter is provably bad.
You can get get parts for this tv at www.interliquidparts.com
slehc_4
Level 1:
Problem Solver:
  • Contributor 4 Answers
  • Posted on May 19, 2014
slehc_4
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
4489
Points
8
We had this happen to ours also, and just by chance realized it only happened when something else was attached to the TV like a DVD player or game station. That was 4 years ago and it still works fine as long as we don't attach something else to it.
Need fixs how do i make it stop flickering?
How do i stop my vizio from flickering? - YouTube
? 2:18
https://www.youtube.com/watch?v=RD2PwPFpbrE
Jul 19, 2013 - Uploaded by colguon38
Please help me stop my TV from flickering. ... 1080p. the monitor will momentarily change resolutions. that is the "flicker" you see. unfortunately i ...
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture EASY ... I have this exact make and model. .... and theflickering didn't stop. any ideas as to which JP I should cut . please help not ready to buy a new TV.
VIZIO flickering Tv screen easy fix( no money ) - YouTube
? 1:58
https://www.youtube.com/watch?v=oWSFwS3FH_c
Aug 28, 2012 - Uploaded by Bill GatesBestfriend
this might work for other tv's too. ... If your not sure you can dothis repair your self please take it to a tv repair shop. The repairshould be ...
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
My 42 inch vizio flat screen started flickering and would stop after about 10 minutes after turning on, however, now it flickers non stop. You can see the picture, just a heavy flickering, almost like...
Chances are its not caps that are causing this issue, that isn't a symptom of failing filters. If your comfortable around higher DC voltages I can give you some information on what to test if your not take it in for repair however expect the bill to start at 100 dollars and go up from there
2helpful
My Vizio LCD TV screen fades to dark. Sound stays on.
I w having this same issue when watching a Blu-Ray disc. I found it to be dependent upon what picture mode the TV was set to. By this I mean certain picture modes would cause the TV to dim during dark scenes of a movie. Changing the picture mode helped a lot.
My screen is dark
You could have a defective LCD screen, If the laptop appears to be running and the hard disk is spinning but the screen is dark then, to determine if you have a LCD screen or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
1helpful
Friend's Laptop Screen has become too dark to work with
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
3helpful
Acer screen looks dark?
1helpful
Dark monitor screen with hidden display in the dark.
You most likely have a defective CCFL backlight, it may have the following symptom:
Vizio L32 picture too dark
Bring it back as you can't get parts for Vizio.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
