Inside drawer alway have black mold
SOURCE: Maytag washer fabric softener dispenser is yucky
There is a 1/4" machine screw in a recessed hole close to the bottom of the agitator. Remove screw. Lift agitator off agitate shaft.
SOURCE: Dispenser still full of water and fabric softener
hiya
this could be caused by a faulty cold inlet valve if the detergent is not being taken away. however if the detergent iis being taken away then the valve is working ok as it fills the compartment with water lifting the detergent out and into the washing machine.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
SOURCE: Kenmore Elite fabric softener won't drain
Is the dispenser full? It could be that it is a bit clogged. I would try just pouring a little very hot water in for several loads and using dryer softener sheets during this time. Let's see if we can unclog it .
SOURCE: Fabric softener stays in drawre
We just had a tech come out to fix this problem for us. Essentially, the problem is that the fabric softener builds up and gets clogged. He cleaned out a solid hunk of frabric softener gunk, and suggested that we dilute our fabric softener with water to keep this buildup from happening again.
SOURCE: Fabric softener not draining
Remove the dispenser drawer by pushing down on the tab at the center back and pulling drawer out. Now, remove the top of the fabric softener compartment and the parts of the soap dispenser and clean them all out. An old toothbrush often helps. Reassemble and replace. They should siphon out now.
