How do you mach the antenna to the cobra 29 LTD Classic?
You are actually tuning the antenna to the vehicle it is mounted on here are some very good resources. http://www.rightchannelradios.com/pages/cb-antenna-tuning-guide-pv-c0-61.htmlhttp://www.wilsonantenna.com/swr.php
Be aware that if your radio has been modified it may produce a dirt signal that an swr meter may read as reflected power. In this case it may be more accurate set with a unmodified radio also if your radio is setup for a linear it may have a deadkey to low for the swr meter to calibrate correctly.
Hope this was of help.
You will need an SWR meter to check your antenna. FIRST.
I would find
help at a local cb shop.. They SHOULDN"T CHARGE to help you SET the
swr. only if you need a part or something ..
I don't charge to
SET SWR"s .. only if the cust needs a insulating washer or another
antenna, or new coax, so-239 etc... I would be glad to help you.. let me
know if we can-- CB Shop Temple, TX
