Nokia N8,Mobilphone,ca 6 MND
Using codes you can unlock your nokia mobile because its safe for your mobile...........Get the unlock code for your nokia n8 model mobile here Superunlockcodes.com , it gives the easy instructions for getting the unlock code for your mobile .........
Hello
You can generate the code by using this tiny software.Just follow the procedure.
1.
Downoad [ANT] Simple Ant Simple.zip
2.
If you have Nokia PC Suite running, be sure to close it by exiting from the
taskbar icon.
3.
Extract [ANT] Simple ] and run Simple.exe located in the folder
4.
Connect the phone via USB to the computer by selecting Pc suit/Ovi suit when
prompt a message in your pone.
5.After
you've connected your phone, Click "Read Info"
6.
On the MAIN tab, click on GET. Your phone IMEI number and model should be
displayed on the bottom panel
7.
Now click on the SERVICE tab and click on GET button under USER CODE
8.
Your security code should now be displayed on the right side of the application
window.
If you could not understand follow this How to Generate Your Phone Security code..Only for Nokia bb5 after this format the phone by using the code.Good luck
Thanks For visiting Fixya
