This has happened once before, I took unit into approved service, they sat on it for two weeks and then told me there was nothing wrong. I re-attached and it worked for another couple years, am having the same problem. Seems if you totally unplug the unit and let it sit, it somehow resets itself, but I've no idea how. What is the solution?
Several things could cause that:
1. hdmi cable is no good.
2. receiver and TV are not fully compatible. I noticed few times that philips tvs had problems with denon receivers. Some times you need o unplug hdmi cable and plug it in back to get sound.
3. firmware issue. depends on model of your receiver there could be a software upgrade to resolve the problem.
4. somebody (kids) accidentally pressed some buttons and reassigned video input for that video source (video select button on a remote control), etc. Resetting the receiver usually helps.
5 Receiver (hdmi board is no good) or TV is no good.
so next time when it happens check video source, video input assign then try to swap hdmi cable and TV
