I am very frustrated with this whole system. The manual goes from one thing to another not even telling you why you would need to do anything(formating). I finally figured out how to get my track to a wave format. Saved it in the Wave file for DP-02, closed the usb connection, and tried to import the song through the "WAVE" option and it says "File Not Found". I don't know if I'm suppose to format the CF Card, Fat Partition or anything. I need help from the beginning please.......
Thanks
Amy & Bobby
You shouldn't have to do any formatting. If you copied a wav file onto the DP-02 while connected with the USB and with the USB connection open, then you were already accessing the fat partition. One thing to be aware of is that the DP-02 only works with mono wav files. So if the wav file from you PC is being saved as a stereo wav (which is the default for most programs) then you'll have to specify mono instead. The DP-02 only works in 16 bit as well so on your PC you should be saving and wav files you wish to import as 16 bit, 44.lkHz mono wav files). That should be about it.
Hope this helps.
bd.
