Question about Nordic Track NordicTrack Elite zi Treadmill
Knocking noise banging noise
  • 2 more comments
  • Matt Olenzek
    Matt Olenzek Dec 01, 2011
    Dave, are you still having the problem?
  • dave allen Dec 02, 2011
    I am still having the problem. Ernesto, thank you for the video links but my problem is neither the motor nor electrical.
    If I walk very softly there's no noise, but if I take a normal step on the treadmill there's a banging noise coming from under the tread as if something needs to be tightened or as if a screw came out completely and something is just hanging. I'm reluctant to take the deck apart since it was shipped to me in one piece. Any advice?
    Thanks in advance,
    Dave
  • ernesto cuadra
    ernesto cuadra Feb 15, 2012
    If it sounds like metal rotating on metal then it could be roller bearings or motor bearings. Its best to have the treadmill work carried out by a technician in the workshop. Most of the time the bearings will have to be pressed out and the new ones pressed in.
  • emeline
    emeline Feb 15, 2012
    I called customer service and we narrowed it down to the Drive Roller. Although we've only had the treadmill for 2 years the bearings have worn down.
  • 297 Answers
Dave, the noise you are having is the walk board( the black wood board under the walk belt), is supported under the treadmill by two rubber isolators. You have either one or both worn out. You should have a black, ground up rubber substance under the front of the walk belt. This is the left overs from the isolator. I can get you the part numbers for the isolator if you agree by looking at the isolator. The last person that tried to help you must not be familiar with your problem. Get back with me after you lift up the treadmill into the stow/storage possition. Look at the front corners where the walkboard hooks to the frame, and you will see what holds the walkboard to the steel frame.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Dec 02, 2011
  • emeline
    Matt, how can you see if the isolators are warn down?
  • Matt Olenzek
    Matt Olenzek Feb 15, 2012
    Dave there are two isolators at the front corners of the walk board. The floor under the treadmill should have black rubber shavings that look like dust. If not he screws that attach the bushing/isolators could have fallen out or as stripped and still in there.
    Dave, get me the model number and i will get you a picture of them.
    Matt
    Top Expert:
  • Nordic Track Master
  • 12,223 Answers
6ya staff
SOURCE:
2004 GMC Envoy has a banging knocking noise in the dash by defrost every time I start it. blower will not switch from defrost to floor or vents
Sounds like the diverter door is bound up causing the motor to bog down under load. You'll need a manual for that job. It's a pain in the rear to get to.
Jan 30, 2018 | GMC Cars & Trucks
I hav a knocking noise under the hood of my jeep cherokee. I recently had the upper ball joints replaced and the knocking stop for a while and now its back full force. The noise sounds like its coming...
Knocking in the engine varies from simple failure to detonate to you are about to throw a rod. This is something that can be difficult to diagnose and if misdiagnosed, costly to repair. I would take that in to a mechanic as soon as possible. Barring that, I would check all your spark plugs.
Feb 14, 2014 | Jeep Cars & Trucks
Knocking noise from front end
bad motor or transmission mount.
Nov 11, 2017 | Saturn Ion Cars & Trucks
Banging noise when you drive
This is a hard problem to describe, I know, and I will toss out a few possibilities. If the noise occurs when the car is accelerating, it can be motor mounts, or carriage mounts on front-wheel drive vehicles. Transmissions can bang into gear. Drive shaft u-joints can bang before they fail. C-V joints in front wheel or 4 wheel drive units can bang when worn out.
The exhaust system can break loose and bang on the frame. Brake calipers can rock in their mounts and transmit sound. Tie-rod ends can make a knocking noise on every bump you hit. There were recalls on gas tank straps for some Ford made units, so a loose gas tank can bang.
Dec 30, 2013 | Mercury Cars & Trucks
When in drive transmission makes knocking noise
make sure transmission fluid and filter are ok. if ok your best bet is to have a transmission person look at it.
Jan 20, 2012 | 2000 Mazda MPV
Dryer makes banging noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
uioiotusdds
Jan 30, 2010 | GE DBVH512GFWW Dryer
Loud banging noise when machine goes into spin mode. sounds like it is banging on the side. Please help !
Usually this is an out-of-balance condition caused by too much weight on one side of the tub, move the clothes around and try again.
Apr 26, 2009 | Washing Machines
94 Accord Banging/knocking when i turn
check the axles for leaking boots or dry axle joints....replace if necessary...also make sure all brake caliper bolts are all installed and correctly torqued
Apr 07, 2009 | 1994 Honda Accord
SHAKING AND KNOCKING NOISE
it could be tht the exhaust pipe is loose and therefor makes shaking and kinda banging noise. hope i helped! ;-)
Jul 26, 2008 | 1994 Jeep Grand Cherokee
Nordic Track NordicTrack Elite zi Treadmill Logo
606 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Treadmill Repairs...
Android Man
Android Man
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
