I would just call a plumber to install your water heater so that everything is done correctly. I wouldn't ever attempt to do it since I don't know how to install a water heater. I think it would just be best for a professional to do it so all is done correctly and efficiently. https://www.rooterexpressmb.net/water-heaters
Open following link for installing tankless electric water heater:
http://waterheatertimer.org/How-to-wire-Tankless-electric-water-heater.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
SOURCE: how to fix my tankless hot water?
what is it doing, I would first check the inlet water screen and make sure that it's clean. shut off the water going to the unit and the screen is right after the shut off, unscrew it and clean it. replace and turn the water back on. you can ask for me again if this does not help
SOURCE: No hot water
The code # 11 is a code that warns of "no ignition" and the causes of this error code are too many to list. I would suggest that a qualified tech. perform a diagnostic test and repair.
This is not a task for the "do it yourselfer"
SOURCE: Noritz tankless water heater/dishwasher not hot enough to clean
You are doing everything you can. Your dishwasher probably isn't drawing enough hot water to activate the unit so opening the faucet and flowing more water will activate the unit. Just try to adjust the flow from the faucet to a point it, plus the draw from the dishwasher, will activate the unit. This will come with trial and error as I am sure you have already experienced. Also, open the dishwasher when it does get filled and check the water temperature. You might have the unit set at a low discharge temperature. Do you have a touchpad to control the water temperature adjustment?
SOURCE: takes too long for hot water.
You need a recirculating line. You will have to hire a plumber to run a water line from the farthest fixture or to the fixture you are concerned about on the hot side and return it back to the water heater. this will cause hot water to constantly run throught the hot water line (via the recirculating line) and when you want to draw water from the fixture, you will already have hot water right at the line.
I know this works with standard tank water heaters, but it is a lil trickier with rinnai units(but very possible) if your plumber pleads the 5th and tries to sell you another unit call the Rinnai manufacturerand ask them how.
SOURCE: will a recirculating pump work with a tankless hot
A Metlund or Taco D'mand system will work Be sure to size it for the correct lenght of the run to the farthest fixture .
