Sony Bravia KDL-42V4100 42 in. LCD TV Logo
edward salazar Posted on Dec 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Code for sony tv - Sony Bravia KDL-42V4100 42 in. LCD TV
Level 3:
Top Expert:
  • Sony Master 76,851 Answers
  • Posted on Dec 02, 2011
Sony Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15002906
Points
237762
Hello
Three digit universal remote codes for Sony TV are:
002/ 006/ 071/ 128
Four digit codes are:
0128 0013 0002 0071 0380
Five digit codes are:
10810, 11685
OK.
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
I need to know how to use rm ed007 remote to set up my sony dvd to play on sony bravia tv
The "rm ed007" remote that you mentioned is most likely a universal remote control, which can be programmed to control multiple devices, including your Sony DVD player and Sony Bravia TV.
To program the remote to control your Sony DVD player, you can follow these steps:
  1. Turn on your Sony DVD player.
  2. Locate the code for your Sony DVD player in the code list provided with the universal remote.
  3. Press and hold the "Code Search" or "Setup" button on the universal remote until the indicator light turns on.
  4. Enter the code for your Sony DVD player using the number buttons on the remote.
  5. Test the buttons on the remote to make sure that they are controlling the Sony DVD player as expected.
To program the remote to control your Sony Bravia TV, you can follow these steps:
  1. Turn on your Sony Bravia TV.
  2. Locate the code for your Sony Bravia TV in the code list provided with the universal remote.
  4. Enter the code for your Sony Bravia TV using the number buttons on the remote.
  5. Test the buttons on the remote to make sure that they are controlling the Sony Bravia TV as expected.
How do I program coolsat remote to Sony TV
Programming a Coolsat remote to a Sony TV is a straightforward process that can be done in a few steps. Here's how you can do it:
  1. Turn on the Sony TV: Make sure that the Sony TV is turned on and in the correct input mode so you can see the on-screen menu.
  2. Locate the code list: Check the manual that came with the Coolsat remote for a list of codes for Sony TVs. The codes are usually organized by brand.
  3. Try the first code: Using the Coolsat remote, press and hold the "Code Search" button until the light on the remote turns on. Then, enter the first code for Sony TVs into the remote. You can usually do this by pressing the number buttons on the remote.
  4. Test the code: After entering the code, press the "Power" button on the remote. If the Sony TV turns off, then the code is correct and you can proceed to the next step. If the TV doesn't turn off, try the next code from the list. Repeat this process until you find a code that works for your TV.
  5. Store the code: If you've found a code that works for your TV, press and hold the "Code Search" button again until the light on the remote turns off. This will store the code in the remote's memory and allow you to use it to control your TV in the future.
  6. Test the remote: Finally, test the remote by using it to control the TV's volume, channel, and other functions to make sure everything is working correctly.
If the codes listed in the manual don't work for your TV, you may be able to find additional codes online or by contacting the manufacturer. You can also try using the "Code Search" function on the remote, which will allow you to find a code by scanning through all the codes in the remote's memory.
What is the code for a 2001 Sony Trinitron?
Search Results
    Sony eSupport - Remote Control Codes & Programming ...
    https://esupport.sony.com/.../select-system.pl?...RCOD...
    Sony CorporationFind the codes you need to program your remote control. ... Television - Accessories; Television - FD Trinitron® & WEGA™; Television - Internet TV & Players ...
    [PDF]Trinitron Color TV - Manuals, Specs & Warranty - Sony
    https://docs.sony.com/release/KV20FV12.PDF Sony CorporationRefer to section 54-300 of Canadian Electrical Code for Antenna Grounding. Lightning .... Congratulations on your purchase of the Sony Trinitron Color TV.
3helpful
Sony remote rmtb119a tv code for magnavox
I just keep trying different codes for for my Magnavox TV. Since they started at 01 for Sony TV's I just keep working up from there. For me it ended up being 22. Here are the complete instructions from sony's site:
Follow these steps to program the remote control to operate a television.
  1. Turn on the TV.
  2. On the remote control, press and hold the TV I/O button.
  3. While holding the TV I/O button, enter the manufacturer's code using the number buttons. 22
  4. NOTE: If more than one code number is listed for the manufacturer, enter one code at a time until you find one that works.
  5. Release the TV I/O button.
  6. Point the remote control at the component.
  7. Press the TV I/O button to verify operation.
Need code for AT&T Universe Cable and Sony Tv , and Sony DVD & Vhs Player, Also need picture of remote.
I was unable to find the code for that specific cable box. The TV was no problem, And I couldn't find the combo code, but I have the Sony VHS code and DVD code. Maybe they'll work.
Sony TV: 002, 006, 071, 128
Sony VHS: 004, 099,128,139,140,141,147,154,155
Sony DVD: 009, 174
I hope this helps!
1helpful
I have sony tv and tv one remote whats the
The manual that came with the remote will have the codes in it. If you cannot find the code for your specific mode, try all of the codes listed under Sony TV.
1helpful
I have a RCA Universal control and a Sony TV but no codes
Press Code Search button Indicator light on.
Press TV button light blink.
Here some codes enter for Sony TV 002,218,099,166.
tries Every these codes the blink light should off.Off On button should work tv goes off or on .
that it u have it
8answers
Tv code
www.usersmanualguide.com/sony/remote_controls
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
