Are there any lights? If not then I would suspect your power supply. If there are lights it is most likelly your power supply but it can also be just about everyother part on that TV. signal board, T-con, power supply. If you need a power supply.
I would try turning off all power to it for few minutes and see if it reset it’s self, before I go to any great expense. Also I had a washer that quit working on one cycle but would work on the others, could try that as well. Hope this helps!
There are several reasons why the Roku won't power on. It could be a defective power adapter or the device itself is no longer working. Try to plug the Roku player to a different power outlet and make sure that you are using the correct power adapter. Check the front panel of the unit and see if the LED is lit or not. If it is lit, it means that the power adapter is actually emitting power. Make sure that you select the correct input source on your TV to see your ROku display.
Getting it out of child lock can be difficult but make sure you watch the light on the front panel it will go right back to lock if your not careful.I had to try several times at first I thought it would need a doctor.. but with patience it should work and unlock with the 4 second hold.. power down does not reset unless you wait 30 minutes or longer.. hope this helps
Control panel lights are behind the panel, so if the compartment lights are on the panel is lit. If no lights are on when you open the door, check your door switches as you may find the light switch has failed. Look there first, no lights, possible just a bad switch.
Good Luck
Is it repairable, well, this question can be answered only after opening the back cover and evaluating the damage. From you side, please connect the TV to a different power outlet where other similar devices are working and see. Then try changing the input device to something that sure works. If it does not work even then, this may need attention by a qualified service technician.
