Could be a problem with the (go) switch check there is power going to it and also check if there is power to the motor other wise it could be the motor check using a testing light
Check wiring and pcb in your chair...it may be loose connection in between the path
jaxxy 1113 chair will start to power up. Yellow light in speed control will flash about 4 times then shut its self down. Bought and changed batteries last night still have same problem.I checked brakes, all plugs and and rechecked battery cables.Charger shows about 3 amps but when charger is unplugged guage goes to 0. Same after 12 hrs charge.motor brushes are a possible solution, not sure what indicator light should show if brushes thanks Craig
acer t 5520 hard disk bios password can not be open bios plz help me bios password and hard disk password resat
Microwave oven is not working at. Earlier it was showing E-10 error, but after few days o cleaning of controller it is showing E-18 error code
oxygen sensor
