Ice maker and water dispenser stopped working couple years ago. Checked water line starting at the water pipe in the basement. Found no water coming through. Replaced the t valve, water line and all connnectors. Water dispenser now working, but when you use it, the water line on the back, top right, that goes into the ice maker is coming loose and making spraying sound. Ice maker stil not working.
SOURCE: KItchenaid Superba KSRB25QABL water dispenser
Chances are is a bad water valve. The water valve is on the back of the fridge at the bottom. You will see the water line going into it.
SOURCE: Maytag msd2556aew
no ice maker on its own circet how are you hooked up to your house saddle valves plastic pipes turn your main line off take it loose get a bucket turn it on and check the flow
SOURCE: Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
SOURCE: Ice Maker GSI-26 dispenses crushed ice and will not dispense cube
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
