Question about Panasonic Cameras
Tz5 won't take pictures. zoom ok
My TZ5 will not take photos. The zoom is ok and playback is also good
6ya staff
SOURCE:
Anonymous
  • 246 Answers
SOURCE: ii need a manual to install my replacment screen for my dmc tz5
this tips may help
http://www.myfixtips.com/blog/digital-camera/how-to-change-lcd-screen-for-panasonic-dmc-tz1-2-102.htm
Posted on May 13, 2009
Anonymous
  • 3 Answers
SOURCE: Camera in japanese language i want in english LUMIX DMC TZ5
Select menu
Select spanner(wrench) for setup menu.
Scroll down through the menu, there are five pages of menu items on my camera! it moves to a new page when you move off the bottom.
The language option is the penultimate item - it has an icon of a head with a speech bubble.
Posted on May 31, 2009
Anonymous
  • 83 Answers
SOURCE: How reliable is the Panasonic/lumix
TZ5 is a fairly reliable and solid camera. It's been out for a while and there are still no known issues with it.
The ones I've been asked to repair have all been damaged due to owners' negligence (usually been dropped, had sand in lens mechanism or suffered water damage). I still haven't encountered a TZ5 which just suddenly "stopped working".
From a repairman's point of view I can say that TZ5, just as the TZ3 before it, is really really well built. It's easy to dismantle and put together. Everything is well thought of. The lens is a work of art.
Of course you need to be careful with this camera to avoid e.g. water or sand - these might kill your tz5. Sand clogs the lens easily (of course this is an issue with just about any compact camera)
I can definitely recommend it.
Hope this helps,
Raf
Posted on Nov 05, 2009
Ty Price
  • 11967 Answers
SOURCE: panasonic lumix DMC-TZ5 flash stopped working. Any help?
Check to see if you've accidentally turned it off. Is there an icon of a lightning bolt in a circle with a line through it on the screen?
Posted on Nov 14, 2009
Ty Price
  • 11967 Answers
SOURCE: Panasonic Lumix DMC-TZ5 does not recognise my memory card
1. Go into the menu and find "reset"...follow the on-screen instructions. 2. With no card in the camera, go into the menu and find "format"...follow the instructions.. 3. After downloading any pictures from the card, insert it into the camera and do the "format" thing again. everything should work now. Remember, never use the computer to format or erase your card...always use the camera. Also, when removing the card from the computer, always use "safely remove hardware" icon at the bottom right of your computer screen.
Posted on Feb 16, 2010
My Panasonic DMC-TZ5 will no longer focus, especially after using zoom. It displays messages re shutting camera off and on, takes 30 seconds to turn off and sounds like a ticking clock! It is only 3 months...
If you mention "ticking clock" sounds, then most probably something like a grain of sand fell into the cogs in the zoom mechanism (been taking pictures on a beach? ;). Dirt gets into the mechanism through the gaps between the zoom barrels and the camera body. One tiny grain of sand is enough to cause the lens mechanism to jam or malfunction.
Unfortunately, this is a problem with pretty much all compact zoom cameras. Usually there is not much you can do with this. First thing I try in cases like these is gently tapping the camera to shift whatever might be blocking the mechanism. If unsuccessul, then only way I know to fix this is completely stripping the lens to clean it or swapping the lens with one taken from another camera ("donors" available on ebay ;).
If you are not keen on tinkering with your camera I would suggest selling it on ebay - TZ5 with lens mechanism issues still fetch pretty good prices.
From repairman's point of view I can say that TZ5 / TZ3 (same lens design) are much better in in terms of "resisting dirt" than various other manufacturers. They are very well made and relatively easy to dismantle and fix. This is most probably the reason why even broken ones still sell quite well on ebay.
Of course, you might get unlucky with most robust piece of kit :(
Well, hope this helps.
Good luck with your TZ5.
Raf
Nov 07, 2009 | Panasonic Lumix DMC-FS5 Digital Camera
Displays file error message when trying to playback still images and video footage
Did you take the card and insert into computer/device to view photos?
Viewing photos can alter the format of the photos thereby preventing your camera from reading them.
I viewed some photos and rotated a few photos and my camera no longer recognizes the format.
good luck
May 20, 2009 | Sony Cybershot DSCW80 7.2MP Digital Camera...
Panasonic DMC-TZ1 operates in Playback mode only
The position from the dial wheel is not corresponding with the electrical position. If you can do it by yourself you can adjust it and tighten the midscrew from the dialwheel
Regards, Rob NL
Apr 20, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
I am comparing the Panasonic Lumix tz5 to the Canon 110sx. My question to you is - have there been any problems with the Panasonic tz5?
i have had the TZ5 for a year now and have experienced no problems, it takes good clear photos and the zoom is brilliant
Jan 31, 2009 | Panasonic Lumix DMC-TZ5A Digital Camera
Saving zoom in photos
You can't. The inphoto digital zoom is just so you can do it. The best thing to do is download the photo to your computer and then use the camera software to zoom/crop etc. Then you can save the altered image.
Dec 25, 2007 | Olympus Stylus 790SW Digital Camera
Deleting from memory card
1. Set camera to playback mode and turn on.
2. Push "W" on zoom button (zoom out). (this will show you the index card)
3. Press the delete button (garbage can button)
4. Choose the top option "All In This Folder"
5. Confirm choice.
Nov 25, 2007 | Vivitar ViviCam 35 Digital Camera
Shooting mode will not operate
Your camera has a defective CCD imager. Please return the camera to Canon in New Jersey and they will replace the CCD at no charge to you. This is a known issue and should be covered under extended warranty. Good luck my friend. Joe Weibel customelectronics.org
Feb 27, 2007 | Canon PowerShot A75 Digital Camera
SLIDESHOW function
You can play the images in your camera on a TV or save them to videotape by connecting the camera with the bundled Audio/Video cable. Power up the camera in the PLAYBACK Mode, press the OK/MENU button to open the menu and using the arrow keys toggle up to begin the SLIDESHOW. You can even change the playback format in the MODE MENU. Press the OK/MENU button and using the right arrow key select the MODE MENU. Toggle down to SETUP, toggle right to enter the SETUP MENU and toggle up once to PLAYBACK SETUP. When you toggle right you will be offered four playback options: NORMAL, SLIDE, FADER and ZOOM. When selected you will get the following effects: NORMAL - Each image instantaneously replaces the previous image. SLIDE - The images are sequenced by sliding from right to left. FADER - The images are sequenced via a lap dissolve. ZOOM - The images are sequenced by zooming in to black and zooming out from black.
Sep 04, 2005 | Olympus Camedia C-5500/C-55 Sports Zoom...
Cameras Logo
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
