Question about Denon AVR-1508 Receiver
I'm trying to connect a Samsung HD LCD tv to a Denon AVR1508 receiver using HDMI cable so that the TV sound comes thru the receiver/speakers. which jack do I use (on both the tv and the receiver,
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Denon Master
  • 1,001 Answers
Portable Bluetooth 4.1 Receiver Wireless Multipoint Connection Audio Music Adapter with 3.5mm AUX Port and Hands Free Calling for Home Audio Music Streaming Sound System https://www.amazon.com/Charm-Bluetooth-Multipoint-Connection-Streaming/dp/B01G8219Y4/ref=lp_14423925011_1_1?srs=14423925011&ie=UTF8&qid=1481685075&sr=8-1
Posted on Dec 14, 2016
    New Friend:
Connect the hdmi to the tv (hdmi input 1) and to the receiver (hdmi output) you must make sure that the receiver input settings are assigned correctly. Then hook up all of your devices to the receiver. remember that the 1508 dosent do hdmi upconversion, so if you have any devices that are NOT hdmi, you need to run rca cables from the output of you receiver to the input of your tv. If you have any digital inputs coming out of your devices, i would recommend using them. your 1508 has two inputs that are assignable.
If all of your devices are hooked up to your receiver, and its hooked up to your tv properly, just turn down the sound on your tv, and turn up the volume on your denon!
Posted on Dec 19, 2011
Anonymous
SOURCE:
I have a new Denon AVR 1911 receiver all hooked up to my input devices and output thru a single HDMI cable to my Samsung LCD tv.... problem with getting audio from my DVD player: my DVD player is older...
Not likely that all those things are faulty.
The TV and DVD player make and model would be helpful to know. I would recommend running its BEST digital audio to the receiver and its stereo analog audio to the TV just in case you want to watch and hear the DVD in a lo-fi setting without the Denon. I generally advocate for connecting anything high-end (audio or video) ONLY to equipment that can use it or enhance it. Otherwise you may just be wasting expensive cable and adding unnecessary hops and connections that can fail.
Why do you want the audio to go from the DVD to the TV through the Denon? Are there no speakers on the Denon? Modern TV's have lots of inputs for the flexibility I recommend but rarely have decent audio or speakers.
May 06, 2011 | Audio Players & Recorders
Can you tell me what are the functions of the two hdmi inputs, and the one hdmi output ,as my cable only works via the tv to the dvd player and a coax from dvd to the coax on avr, so hdmi on avr is...
Let's treat this as TWO functions - audio and video.
Your best video would be HDMI output (audio & video) from the cable box and EACH other video source (BD/DVD) directly to your TV and receiver. But, I'd still WATCH the video from the direct TV connection. The fewer intervening cables and electronics, the better.
Your best audio performance will come directly from each multichannel source via a digital (HDMI, coaxial or optical) cable to the receiver. I would LISTEN to audio through the receiver for best quality.
See a trend here? TV's best at video; receiver is the master of audio.
And neither one adds much by handling the other. Usually the opposite.
You mention coax. Do you mean coaxial digital audio????? As coax is also shorthand for the thick black cable bringing video to most cable boxes, connecting antennae to TV's and such.
You don't actually define what the problem is. Only YOU can be the judge of what 'better' is.
There are a multitude of (mis)settings you should master before declaring a hardware problem. I'd dive into the manual.
Aug 03, 2010 | Denon AVR-1508 Receiver
I want to connect my denon 790 to my 5:1 surround, HDMI DVD player and HD samsung 55'' LCD. what cables do i need and where to put them. thanks
You will need 1 HDMI cable to link between your DVD player and the Denon,plug the HDMI cord into the HDMI port on the back of your DVD player and the the other end into the Denon 790 HDMI port labeled DVD,then you will need another HDMI cord to go between the Denon and your LCD TV,plug one end of the HDMI cord into the Denon 790 HDMI port labeled HDMI monitor out and the other end into one of the HDMI ports on the back of your TV, it doesn't matter which one you use, just remember that you will have to change the input on the tv to that specific HDMI port when you play back a DVD and you will also have to change the Denon to DVD as your source to send the audio through the Denon to your surround sound speakers.( The Denon owners manual will help!!)
Nov 26, 2009 | Audio Players & Recorders
Hi denon to cable box to samsung lcd
Unless you are having res. issues you can use component / optical / coaxial cables to connect all your devices to your denon and from your denon to your tv using component cables also
Feb 25, 2009 | Denon AVR-5803 Receiver
Best way to hook up all my componets
The best way to use the Denon and get your money's worth is to connect all devices to the Denon using HDMI connects if possible, if you use HDMI make sure you assign the audio if needed.
HDMI from Denon to TV. the Denon will upconvert all signals to HDMI to the TV
Jan 29, 2009 | Denon AVR588 Receiver
We have a Denon AVR Surround Sound receiver, a Samsung HDTV, an XBox 360, an ASD-3W Denon Ipod Dock and Klipswitch speakers with a subwoofer, center channel and too bookshelf speakers. We need help...
HDMI input connect as follows:
1. Connect an HDMI cable from the Cable box to the TV/CBL HDMI input on the Denon.
2. Connect an HDMI cable from the Xbox to the DVD/HDP input on the Denon.
3. Connect an HDMI cable from the HDMI out-put on the Denon to an input on the Samsung.
You don’t have to use the optical output from these to devices since the HDMI cable allows for the transfer of both audio and video, if you have them extra use them in addition to the HDMI cable and last,
4. On front of denon after you setup and assign your optical connections, if you use them, once you select TV/CBL or DVD/HDP as a source, press the input mode button to select auto
Jan 08, 2009 | Denon AVR588 Receiver
Connection help with receiver and lcd TV
depend on what you wants to do. if you wan to get sound from your tv on receiver connect out from tv to in on receiver if U have optical out from tv send this to optical input on your receiver and set up your receiver to impute to digital HDMI carrie sound and video...
(My Denon receiver set-up shows an HDMI cable going from the Video Out on the TV to the HDMI MONITOR OUT on the receiver)
OUT TO OUT don't make sense ...could be out to impute you may have HDMI going from receiver to TV and other HDMI imputs on receiver to use receiver as distribution unit say you have satellite HDMI, DVD HDMI, Computers HDMI IMPUTE all of this connected to your Receiver and the HDMI monitor out from your receiver connected to TV so now you may select any of this sources to wach In your TV and lessen trough receiver speakers
Apr 10, 2008 | Sony BRAVIA KDL-40V3000 Television
Denon Avr-588 setup
dojran,
nice gear. Without further information, i am going to describe the best setup possible with your equipment.
1. make sure the speakers are connected to the receiver and you can hear sound out of it
2. connect cable box to receiver via hdmi to receiver.Choose cable on the receiver or video1 etc. (if you are not using hdmi cables post annd i will walk uthruogh a non hdmi process)
3. connect a hdmi cable from thee receiver monitor output area to the tv hdmi input
4. connect the dvd player hdmi to the input of the receiver
to watch select the tv av mode to line up with the receiver and choose video1 for tv and dvd to watch dvds on the receiver.
good luck
smeags
Jan 03, 2008 | Denon AVR588 Receiver
Denon AVR-1508 Receiver Logo
465 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
