Computers & Internet Logo
A
Anonymous Posted on Dec 05, 2011
Mac OS X Lion compatibility with HP officejet K80
I can't print on my HP officejet K80 using the Mac OS Lion operating system
kenneth njonjo
Level 3:
Top Expert:
  • Master 1,575 Answers
  • Posted on Dec 05, 2011
kenneth njonjo
Master
Level 3:
Top Expert:
Answers
1575
Questions
Helped
365536
Points
4558
Hi Li Louba,
Thats right,you cant print because there are no Hp K80 printer drivers support for your Operating System[Mac OS Lion] as yet.Check out your printers compatible Operating Systems here.
Hope this helps.Thanks!
How do l download hp laser jet 1018 to mac book air.
The 1018 is not supported by HP with the Mac OS Mountain Lion. I found this on an HP forum and it worked for someone else. You could try this:
Thank you for posting,
Unfortunately, HP laserjet 1018 is not suported in Mac OS X 10.8 Mountain Lion. How evere you can use the builtin drivers that goes along with the operating system and select teh driver of another printer and check.
Connect the printer to the computer and then go to System Preferences and click on Print and Fax. In the Print Fax window, lick on the Plus sign and you will find the printer, please select the printer and then under print using click on the drop down and click on "Select print Software" and in the list, please select HP Laserjet 1015 pr HP Laserjet 1022 and check.
If you don't find these printers in the list, please download and install the latest print driver version 2.12 from the apple web site using the link below.
http://support.apple.com/kb/DL907
After downloading and install the update, please try the steps given above.
Is netgear45 compatible with hp laser jet 1102w and mac
Works with Mac OS X v10.4, Mac OS X v10.5, OS X v10.6, OS X v10.7 Lion, OS X v10.8 Mountain Lion, OS X v10.9 Mavericks, or OS X v10.10 Yosemite.
It is wireless, so it should work with Netgear 45.
See this page for more details
EmptyPortlet
Hp officejet 725 compatible with Apple OSX?
If you simply go to hp.com and look up the Officejet 725, and then look for Drivers, you'll see that they only have Windows and Linux drivers.
Therefore, unlikely that you will have support for OS X on it - other than maybe printing...
3095's won't work with mac lion
The Brother HL-3095CW is a color laser printer that is not natively compatible with Mac OS X Lion.
However, there are a few ways to get the printer to work with your Mac:
  • Download and install the Brother printer driver for Mac OS X Lion from the Brother website.
  • Use the built-in AirPrint feature in Mac OS X Lion to print wirelessly to the Brother HL-3095CW.
  • Use a third-party software such as Gutenprint or CUPS to add support for the printer to your Mac.
  • Use a print server to connect the printer to your network and make it available to your Mac.
It's important to note that this printer was released in 2009 and Brother's support for this device and Mac Lion will be limited. It's recommended to check Brother's website to see if the printer model is compatible with the latest Mac OS version and the support for the printer model.
If you continue to have issues with getting the Brother HL-3095CW to work with your Mac, it would be best to contact Brother technical support for further assistance.
Hp printer won't print mac word doc
I wonder whether the Word Doc SDK I am testing these days can help with the related programs?
How to Get Started with VB NET Word
I installed a (mac os lion). In my hp mini's
You need to re install your windows operating system. You can use OSx on IBM compatible systems but then you will face problems with leagality. Apple don't want you to run their OS on something that isn't made by them. Even though all of the parts are the same (just cheaper) If you are lucky you may have a restore partition on your system, to access this you need to restart and press "F8" then pick "restore to default(or factory)" Hope you are lucky.
I HAVE MAC BOOK WITH OS 10.5.8 I GOT HP OFFICEJET L7500 IT HAS NO DRIVERS FOR MAC
From HP driver site,
"Many drivers for HP products are built into the Mac OS X operating systems, or are available through Apple Updates. You can use these drivers by simply connecting the product and adding the product to the printer list. If you installed the product in this way, you received the print driver, fax driver (if applicable), and the HP Utility print management software"
Grand Canyon Tech
Grand Canyon Tech
