1)ADJUST THE SENSOR REED SWITCH BY 1/8" SEE THE DIAGRAM
2) IF YOUR SISTEM HAS BATTERIES EXCHANGE BY NEW ONES.
3)TIGHT THE FLEXIBLE CABLE FROM THE KEYPANEL VS DISPLAY BOARD AND THEN TIGHT THE CONNECTOR FROM THE DISPLAY BOARD VS LOWER BOARD OR MAIN MOTOR CONTROLLER BOARD.
4) WILL BE A GREAT IDEA IF YOU CAN MEASURE WITH YOUR VOLTEMETER +5VDC coming from the main motor controller board to display board.
Now if there are missing the fault: is main motor controller of course after you did the first step or the voltage is there the display board is faulty.
E.CUADRA
MANAGUA, NICARAGUA.
