Check
http://support.nextbookusa.com/support/index.php?/Knowledgebase/Article/View/84/0/reset-instructions-for-nx785qc8g.
1. Hold down the
Volume (+) and the Power button at the same time, until you see
No Command on your screen. (The tablet will act like it's going to turn on and go black, continue to hold your buttons until
No Command shows up on your screen)
2. Release your buttons when you see the
No Command appear on your screen.
3. Tap the
Volume (+) once, and a blue menu will appear on your screen.
4. You will use the
Volume (-) to navigate and the Power to select. Tap the
Volume (-) until you highlight
"Wipe Data Factory Reset"
4. Press your Power button to select it.
5. You will see a list of "No's" and one "Yes." Use the
Volume (-) to go to the only
YES on your screen.
6. Press your Power button to select the
Yes.
7. This will prompt your tablet to go through the motions of resetting itself. When you see the words
''Wipe Data Complete", tap your Power button once to select
Reboot System Now.
8. Your tablet will power off and power back up on its own; this will take a little longer than normal, so give it a couple minutes before it boots.
