Fuse blew on opening main door; main oven not heating; everything else ok
Oven went 'pop' on door opening; after switching main trip switch back to on, everything worked including fan with exception of main oven. Clearly not element, but maybe thermal switch?
Parts #: W10317343
Substitution: WPW10317343 $145.98 at sears
Parts #: W10354052
Substitution: WPW10354052 $125.92 at sears
Part #: W10317347 front LED board $230 at sears
Many ovens have a bi-metal thermal fuse-also called a thermal limit switch-that protects the oven from overheating. The oven thermal fuse trips when the temperature in the oven gets too hot. After the thermal fuse trips, the oven won't heat. If the thermal fuse trips after the self-cleaning cycle, try resetting the fuse by turning off electricity to the oven, removing the exterior back panel, and pushing the reset button. If the fuse tripped during normal operation, replace it. If the problem persists, the electronic oven control board might require replacement. Reset the thermal fuse after replacing the control board.
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Open the lower oven door and remove the 2 screws on the left and right trim pieces. Be careful not to drop the trim pieces and bend them. Locate and remove the screws on each side of the control panel and push up on the panel gently to get it off the hangers. Behind the control panel is an over heat fuse that has popped. It plugs into a harness on the back side of the panel. This trips/breaks it's connection from either the oven over heating the cleaning cycle or just from age.? Once fuse is replaced you're good to go. Hope this helps.
Member Discussion on Whirlpool GMC305PRS01 Microwave Oven
Whirlpool Wall oven/microwave combo unit Door message Does anyone know where the 15 amp fuse is? I replaced the 20amp fuse and it worked for a minute or two and then I opened the door and I blew my circuit breaker. I reset my circuit breaker, replaced the 20 amp fuse and now all I get is the Door message. I also noticed that it fused the outside switch on the right side of the door so I had to open the switch up and un-fuse it. This is for a whirlpool GMC305PRS01 Wall Oven/microwave combo unit.
Also if anyone could tell me the correct position the wire is supposed to be hooked up on the switches? I had someone help me take the switch out and they unhooked the wires and now we aren't sure how they are supposed to be hooked up. My light on the microwave doesn't work either. Is it possible the bulb blew when the fuse blew?
ok that means the oven has a faulty element that shorts when heating up. have all the elements checked one by one eg by eleminating them one by one when you put them on
blue waffle is nice and i like to pop fish up my **** go to google and type in lol fish and then click im feeling lucky and do the same with blue waffle xx good look it could help your oven.
Try running it with the element disconnected, if it does not trip, then element is causing prob.
If it still trips, then look elsewere for prob,.
Please rate my solution.
Thanks.
the electric went off wasnt sure why at the time but when i reset the trip fuse my oven stopped heating up so somethingobviously blew in the oven to cause the the elctrics to trip,
does anyone know how to replace the heating element, also the fan on the top isnt working either
yes the oven thermal fuse blew when the fan went off its also called a tcoswitch if you pull out the oven and take the top off there will be a tech sheet there that will give the location of the tco some are on top some are on back this can also happen if the oven is too tight in the cabinet not enough room around it to let the heat dissipate its a round metal disc with two wires on it
what makes you think it is not the element?
it likely is
Second oven OK
