Large yellow stain / tint / spot when showing bright or white background
So, I just noticed a large yelowish stain in the center and a little over to the right area on my LCD. I is noticeable when running white or very bright pictures. I was able to notice when using it as a computer monitor. because my windows background is white, I was able to see it. Now, of course, I will never be able to ignore it.
My TV is 3 years old. Not a heavy user. Technical support in Brazil isn't very specialized. They would probably replace the LCD panel but that would make it not worth, and I'm not sure that is the problem.
Have anybody had a similar issue?
Thanks!
Try calling the US support line and explain your problem. It's on the Playstation.com site under support. Make sure you click on North America to get the correct number.
http://repairs.sunnyoasis.com/sonylcdtv/ this is a link on what to do i had same problem picture is like brand new now good luck this takes about 3 to 4 hrs
Have you ever experienced washing machine stains, where your machine is the culprit for ... Just never put clothes in when doing this as it will discolor them. ... I get largeyellow spots on my Battenberg linens after washing, or maybe they ...
The Clorox CompanyFeb 4, 2010 - I do my laundry at a neighborhood laundry that has. ... into the machinefor the wash cycle but still get the yellow spots. ... Since you diluted it in a gallon of water, the yellow spots/splotches should not be from the liquid bleach. ... Rinse and air-dry to see if it has any effect before doing a large number of items ...
what not book?, 1984 to now. vast types. made. by HP
what OS. what operating systems.
chrome, the browser chrome?
sounds to me like hardware failure. but .... little to go on , here.
May have burned CRT(s), (if you are not talking about convergence.) Burned CRT shows when that CRT (R,G,orB), does not show in an area of the screen where it should. Check bright white color = full R, G, and B CRT brightness. Gray = mid RGB brightness. Yellow = R+G(no B), Blue-green = B+G, no R, etc.
I havw a simialr problem mine is a blue stripe toward the center of the screen. The problem is most likely from the blue lens on mine or the yellow on yours. I was able to adjust it out somewhat and I am still tweaking it by using a setting in the technical menu called stripe.
You can access the technical menu by pressing the fowllowing on your remote:
TV shows large red spot in middle of tv when dark show are on, you can see it more. Now blue spots on upper right side too. Spend way to much on this tv to have these kinds of problems only after 3 yrs.
I have recently developed the same yellow spot problem on my Sony KDF-E50A10 50" LCD television...a large yellow circular hue that takes up the bottom center of the picture and is especially noticeable against a white background. It has been diagnosed as the optical block (light engine) and without an extended warranty Sony refuses to assist with the repair cost. Repair was estimated at $1,100 plus tax and travel fees to my home. So you see, it is not only a Hitachi problem. You would think they could build something that would last more than two years considering the initial cost of over two grand for the TV !
Some people have a scale on their T.V. somewhere, or for most cable users it shows on the menu an area where you can change contrast, color, tint, brightness, ect...
