Question about Toshiba 50HDX82 50" Rear Projection Television
Toshiba 50HDX82 50 in. Rear Projection Television-HDMI to my TV?
I have Toshiba 50HDX82 (Projection TV) which does not have HDMI input on the back but has HD color stream (5 jacks). I bought a new blu-ray player which has only HDMI output on the back. I bought a cable HDMI to analog/HD color stream (5 jacks). But when I connected the blu-ray player with my TV it did not get any picture through this cable. Does anyone know if my TV converts the HDMI signals itself or Do I need to get a converter box? And how much will it cost, since my blu-ray is only $40 and wont be a good idea to pay a whole lot for the converter. Also, let me know if any other suggestions. Thanks in advance.
  • 3 more comments
  • Pratik Solanki Dec 11, 2011
    Thank you for your response.
    I am confused, my TV does not have any VGA input. It has 3 RCA, 5 HD color stream (Y,Pb, Pr) and DVI/HDCP in. I am not sure if this VGA would work with it.
    Please advice.
    Thanks.
  • Pratik Solanki Dec 14, 2011
    Thanks for your response, But I am not connection computer to TV, I am connecting blu-ray player to my TV.
  • Pratik Solanki Dec 18, 2011
    Thank you for your responses.
    I have tried a cable HDMI to DVI, which worked fine with my TV but the only issue is, DVI can only receive video signals. Does anyone have idea, where I can get a cable with one end HDMI and another end DVI + 2 audio (red & white)?
    Thanks.
    Does anyone know, If I get a simple HDMI to RCA (3 wires) cable and will it work without any converter in the middle (from my blu-ray player to TV directly)?
  • Pratik Solanki Dec 19, 2011
    Thank you J. Millmack,
    But that was my issue, my blu-ray player does not have any other output except one HDMI output, nothing else.
    Any suggestions?
    Thanks.
  • 616 Answers
Use the hdmi to dvi converter this is for video only. use the dvd players analog audio out R- L, TV has to have an audio input for the dvi port.
Posted on Dec 18, 2011
  • Toshiba Master
  • 1,257 Answers
Hmm, I have not worked with this model of TV. All I can ask, if, you pressed input on the remote to receive the connection you completed? And be extra careful, that you put each cable connection exactly where the belong. Thanks for asking me.Matt of Martins TV.
Posted on Dec 12, 2011
  • Toshiba Master
  • 17,130 Answers
It is best you can get a HDMI to VGA convertor which is not very expensive and can solve the issue.Please visit the nearest electronic store and get one that suits with the least expense.check this link for types of converters.
http://www.google.co.in/search?q=hdmi+to+vga+converter&hl=en&rlz=1C1RNAN_enIN461&prmd=imvnsrfd&tbm=isch&tbo=u&source=univ&sa=X&ei=O-jiTsCpI9GsrAeEq_2cCA&ved=0CFQQsAQ&biw=1366&bih=677
Posted on Dec 10, 2011
    Top Expert:
  • Toshiba Master
  • 76,204 Answers
Hello
You have to buy one converter box. Your TV does not accept or process HDMI signals.
  • The Knight
    The Knight Dec 11, 2011
    Hello
    According to the description you have given nere about your tV, It has Y,Pb & Pr inputs to which the TV can accept component video IN. Y=stands for Luminance, Pb=stands for Red colour inofrmation and Pr=stands for Blue colour information. Green colour is decoded inside the circuits of the TV, as we fed it with Re,Blue and Luminance signals.
    Computer outputs VGA signal [Video Graphics Arrey]. There are TVs now, that can process this VGA signal inside it, and they will have built in citcuits to process VGA input we fed into.
    It is best for you to buy one VGA to Component Video Output converter, and connect it in between compter and your TV, and select the input of your TV to appropirate input selection. You will also need a component video cable too to connect this converter to TV, and a VGA cable to connect the converter to computer. I thinks that I'm clear. OK.
  • The Knight
    Sorry
    I've made a mistake in typing the tyes of component video. Y=stands for Luminance signal, Pb=stands for Blue colour information and Pr=stands for Red colour information. OK
6ya staff
SOURCE:
Does my toshiba 50h82 have an internal digital converter?
I doubt the model as old as it is will work without a converter.
Oct 25, 2012 | Toshiba 57H82 57" Rear Projection...
Toshiba 56hm195 tv picture freezes
Check to see if using HDMI input and if so try component input and also advise me if using box of some sort.
Mar 12, 2012 | Toshiba TW56X81 56" Rear Projection...
My 52" Toshiba DLP just dropped an HDMI connection... There are two connectors on the back, both have worked fine until just now when one disappeared from the inputs menu on the screen.
I'm not sure about your tv model as question post shows it is Toshiba 52HM84 that has one HDMI input at rear and you said 3 HDMI inputs in your tv.
Please unplug tv from wall socket for minute or so to get it reset, replug back in, turn it On and check its HDMI inputs appear or not.
Also check for Reset option in Menu for factory default settings that can also help you to get back disappeared HDMI inputs.
If all that does not solve the issue then it seems hardware problem with HDMI circuit board and tv repairman is needed for visual check to get it fix.
Hope these info will help you.
Thanks.
Jun 04, 2010 | Toshiba TheaterWide 52HM84 52" Rear...
57H83 57 in. Rear Projection HDTV Television: I have a Toshiba 57H83 and recently purchased the ...
I would suggest to leave your directtv hd/dvr box connected the way It is.
The HD Colorstream 1input on your TV should work just fine.
This TV does not have an HDMI input but you can buy an adapter and connect to DVI/HDCP IN and that might be able to get 1080i video resolution on your TV.
Jun 30, 2017 | Toshiba 57H83 57" Rear Projection HDTV
My hdmi input wont work any ideas? i hook my pc to tv thru hdmi and i switch to that chanel and my screen is black what do i do
shutdown pc completely. unplug hdmi cable. turn tv on. plug cable back into pc and power up. pc should recognize the tv.
Jan 11, 2010 | Toshiba 46H83 46" Rear Projection...
HDMI slection not working
I contacted Toshiba and they said to turn the TV on first, then turn on the HDMI device.
May 29, 2009 | Toshiba TheaterWide 52HM84 52" Rear...
The sound does not work on my 50H81 Toshiba rear projection HDTV, when it's in the HD mode. It was working prior to being moved & was hooked up through a Bose surround system. The sound on the TV works...
Check to see if the comp inputs have a red and black audio input. Those must be connected, second go inside the menu and make sure the inputs match..good luck..
Mar 09, 2009 | Toshiba 50H81 50" Rear Projection...
Selecting the HDMI input Hitachi 57F500 57 in. Rear Projection
Find Product Owner Instruction Manuals Some TV's auto sense a signal present and switch the HDMI automatically. You can find out for sure with the manual for your TV from this site
Feb 27, 2018 | Hitachi 57F500 57" Rear Projection...
Samsung HL 61A750A1F
The Samsung Television has 3 HDMI inputs, You would connect an HDMI cable from the Cable box to your television and go into a menu on the television to select the appropriate HDMI input.
New cable boxes should have the HDMI connection.
Most Flat screen televisions I've seen have an input button on the television itself. Pushing it should allow you to switch between inputs.
Sep 04, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Toshiba 50HDX82 50" Rear Projection Television Logo
287 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
