Toshiba 57H81 57" Rear Projection Television Logo
Anonymous Posted on Dec 09, 2011
My screen is green, tryed adjustment knobs but doesn,t clear up
Repairman said green bulb is bad, where can I get a new bulb?
I have a sony kp65ws5500 rear projection tv screen turns green then black when turned on.
Yes the green CRT is almost impossible to find any longer they have all been discontinued.
Background color green
adjust the red/blu/green grayscale knobs they should be in the back and, clearly marked.
turn color off then adjust until grey looks right then: turn color knob back on.
Screen turn green tv is 57 rear projection
Good Day,
It appears that you may have a green drive issue. Try adjusting the Sreen Control it is located in the front of TV.
1) Remove Speaker Grill (it just pulls off) start at one end, 2) Remove cover (5-6 screws), 3) Adjust control. The control is located on lower right side towards bottom. A small black device with 2 rolls of controls, adjust the center control on bottom row counter clock wise, until you get a black and white picture.(adjust with color control to min).
If this does not work you light bulb (CRT) is bad about a $750.00 repair.
Good Luck, Big Irish.
Has horizontal lines running through screen,had it fixed when it wouldnt power up.a week later have the horizontal problem
problably when the repairman fixed your first problem, he touched the adjustements on the block focus assembly, there are 6 knobs (2 for each tube red, green and blue) one is for the focus and the other one is for screen or also called G2. you must get a technician, there is a very high voltage there
Screen is all Shades of Red....
You need to remove the front tv panel, search for the screws right behind the screen and speaker area on the sides of tv. Should be four of them, carefully remove the lower have/quarter and you will find a control box, 6 knobs. Try adjusting them to clear the problem, each color has its own knob, be sure to mark their original position befor adjusting. When you find the red adjustment knob, you should be able to turn it down enough so that it doesnt overpower the rest of the colors. Good luck.
2answers
Clear picture
Do not adjust any knobs as instucted in the previous thread if you TV have a convergence problem. Doing so will only make things worse. The blog does however show you how to fix other common problems with these sets.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
50 inch hitachi green screen all the screen has a strong tint of green tried picture adjustment dont even get it close
I have the the same problem with my 60 inch Rear HD projection Hitachi. The bad part is we just bought a bulb 2 months prior to the green showing up.
Model 9P6040C104
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
1helpful
3answers
Sony kp-51hw40
Yes you have bad green and red crt but with an adjustment you can still use it. remove the front panel and you'll see the focus pack (it;s a black piece with 6 rotating knobs on it. Adjust clock otherwise the red and green screen (the bottom line knobs) till the lines has gone. The better way to check it is to adujt in video input with no signal, just black screen.
Green and red shadows
try adjusting the color purity knob.one by one,or if it is really bad tube u can extend it by rejuvinating it.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
