LG 47LC7DF 47 in. LCD HDTV Logo
Posted on Oct 02, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
NEED TO GET SOME LG PARTS
WHERE CAN YOU PURCHASE THESE? I OWN A VIORE THAT USES LG PARTS. I need the lcd screen for my 47lc7df lg television. Mine got hit and broke...Can anyone please help me???
  • 2 more comments
  • anttone Oct 02, 2008
    I cracked and broke my screen on my lg 47lc7df television...Where can I buy one?????
    My sharp 56 inch lcd wont power on although the bulb turns on for about 4 seconds than turns off....I checked the ballast and thats fine as well....The color wheel on the other hand spins and than stops.....Do i need a new one???
    My samsung hlp5663w wont turn on, i tested the bulb and ballast both fine...The color wheel is fine as well...What else can it be????
  • Anonymous Nov 16, 2008
    I have a LG 37LY95 and I need a replacement screen, does anyone please know where I can buy a replacement screen in the UK? thanks
Chen Pei
Level 2:
Sergeant:
Habit-Forming:
  • LG Expert 109 Answers
  • Posted on Jan 17, 2017
Chen Pei
LG Expert
Level 2:
Sergeant:
Habit-Forming:
Answers
109
Questions
0
Helped
138651
Points
612
This site provides lg parts, the quality is very good, the price is relatively affordable! http://ydtparts.com/product/lg/optimus-g3/d725.html
Kevin Kennedy
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Jan 03, 2013
Kevin Kennedy
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
4667
Points
33
3 Related Answers
Dewayne Turner
  • 87 Answers
  • Posted on Feb 08, 2008
SOURCE: NEED TO GET SOME LG PARTS
You likely will not be able to get the parts from LG. The Viore is made by more than 1 company. The serial number will likely help me detrmine me what company made the set.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Chris Sorrows
  • 136 Answers
  • Posted on Aug 08, 2009
SOURCE: LG 47LC7DF LCD TV turns off with a pop then turns back on.
Sounds like a overheating issue. Try facing a large fan blowing across the back of the unit and see if this changes anything. If it does, it might help to blow the back out with compressed air as dust might be helping it overheat.
Anonymous
  • Posted on Jul 23, 2010
SOURCE: Problem for LG 47LC7DF 47 in. HDTV LCD Television
television just flashes red and takes at least 15 minutes to turn on after turning off and on and makes a popping sound.
Ir board sensor for 47" lg flat screen
They would have to purchase it from LG (brand indicated here)
it will be on that board (some are on same board as buttons or separate board.
like this without the metal frame in most cases--item in picture is under 1/2 inch tall.
1helpful
LG 47LC7DF Power surge (lightning) blew out hdmi and rgb and pc inputs, still have antenna and av inputs working. Is this an expensive fix?
you will need a new main board, your set has several different variations. The cost of the replacement board can range from $100-$150 from reliable sources. If you decide to order a new board, you will need to find out the part # of your main board so that you are ordering the correct board.
How do you get the tv to connect with the wireless internet router?
The manual is here if you need it:
http://www.lg.com/us/tv-audio-video/televisions/LG-47LC7DF.jsp
After perusing the manual, it looks like the TV may not have a network capability...
wired or wireless
When I turn the tv on, it first flashes green 19 times, then on the 20th it stays on and the screen seems faintly backlit but no indication of a signal, i.e., on-screen HDMI input selection. It's just a...
I hope our talented expert would have given you correct and helpful info in chat session from related service manual, let me know if you need further help.
Thanks.
Problem for LG 47LC7DF 47 in. HDTV LCD Television it just flashes red and takes a couple of minutes to turn on and makes a popping sound..
47LC7DF Powering up issues
Some of these LG models have ben recalled due to faulty power boards. You might want to check it out on the net
1helpful
LG 47LC7DF LCD TV Remote Sensor not working
IR senor may not be bad. Try using a different remote (universal) and program to TV. If universal remote works and your doesn't, you may need to purchase a remote instead of IR board. If you confirmed that the IR board is bad then replacing the IR board will fix the remote issue. IR board is an easy fix. Just open the back cover out and it's located right in the middle toward the bottom of the TV.
47lc7df
I ordered a Sanus VMB1 kit for the some problem and I believe it should fix it for mine.
3answers
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
