I cannot access my emails in my outlook account on my Toshiba CB50 Laptop it keeps saying theres a problem with my account why is this?
Solution: Make sure that your computer is connected to the Internet or your network. Use a Web browser to see whether you can access Internet sites. If you are on a local network, see whether you can access intranet sites. For information about checking the status of your network connections, see Mac OS Help. Solution: Verify that Outlook is online. On the Outlook menu, make sure that Work Offline is not checked. Cause: Some POP and IMAP e-mail accounts use an outgoing mail (SMTP) server that requires authentication. Solution: Turn on SMTP authentication for the POP or IMAP account. Some e-mail services, including MobileMe mail accounts, require authentication for their SMTP server. If you verify that all your account settings are correct, but you still can't send messages, try turning on SMTP authentication. On the Tools menu, click Accounts. In the left pane of the Accounts dialog box, select the account. Under Outgoing server, click More Options. On the Authentication pop-up menu, select the authentication type, and then enter your credentials as necessary. Cause: Your ISP or network has a firewall that blocks connections to your e-mail service's outgoing mail (SMTP) server. Solution: See if your ISP or network administrator can provide an alternative SMTP server to use for your POP or IMAP account. If you have the address of an alternative SMTP server, enter it in your account settings. On the Tools menu, click Accounts. In the left pane of the Accounts dialog box, select the account. In the Outgoing server box, type the server name or address. NOTE: If you use a laptop computer in multiple locations, such as at home and at work, the SMTP server that you use in one location may not work in other locations. Each Internet connection that you use may have a firewall with its own restrictions. Cause: Your credentials or account settings are incorrect. Solution: Verify that your account user name, password, and other settings are correct in Account preferences. On the Tools menu, click Accounts. In the left pane of the Accounts dialog box, select the account. Make sure that you have entered the correct e-mail address, user name, and password. If your account still does not work properly, check with your e-mail service provider for details about how to configure your account in a mail application. Your account may require that you use special settings such as Secure Sockets Layer (SSL) to connect, or that you override the default port. Cause: Your network requires a proxy server to connect with the mail server. Solution: Specify a mail proxy server in your computer's System Preferences. If you use a network to connect to the Internet, you might have to specify a mail proxy server. Ask your network administrator for the correct settings for your mail proxy server. For instructions about how to enter these settings, see Mac OS Help. Cause: Your e-mail server is unavailable. Solution: Make sure that the mail server is online. If you successfully connected to the account before, the mail server might be offline. Contact your e-mail provider or network administrator to see whether the mail server is available.
There is no gear icon on my Google calendar. I want to change the view from today to this week. Not in Settings either. I have a new Samsung galaxy tablet
I cannot access my google mail account that I have been using for months - why are you changing access?
Trying to access my cld calendar. I am transferred to Google which does not recognize my password
I'm trying to get to my calendar info at Roxanne.com and can't access it
I have tryed to get in to get in all accounts but I've forgotten my password or though I thought I did but I've tried every password that I've had but it still won't work
check out July 2018 Calendar -https://freejulycalendar2018.com/
