My battery keeps dying, but the owners manual list nothing about the battery except that it's a maintenance free battery. I don't know what to do.My battery keeps dying, but the owners manual list nothing about the battery except that it's a maintenance free battery. I don't know what to do.
AnonymousMar 24, 2014
92 tajoe cables unde fuse box burned at least 4 the mail problem was the cable that goes to cigarrete lighter, can i replace all cables and due they sell them92 tajoe cables unde fuse box burned at least 4 the mail problem was the cable that goes to cigarrete lighter, can i replace all cables and due they sell them
AnonymousMar 28, 2014
No power. Battery is good. Want to check main fuse.... Where is it?No power. Battery is good. Want to check main fuse.... Where is it?
You can't post conmments that contain an email address.
? 3:18
www.youtube.com/watch?v=mU0sgQn-0qw
Jun 19, 2015 - Uploaded by Justin Shiffler
PT Cruiser manual stick shift cable bushing tip ... how hard was this to replace? my right bushing is gone and ...
? 1:06
www.youtube.com/watch?v=MiHSkqSrsLY
May 8, 2013 - Uploaded by CJ Turner
Shifter cable broken for the third time ... Chrysler PT CruiserBrake Light Switch Replacement, Shifter Stuck .
CHECK YOUR BATTERY LEADS EITHER ON THE BATTERY OR THE EARTH WIRE TO ENGINE AND CHASSIS OR FEED WIRE TO STARTER MOTOR
unless you have a fuse or relay jumped out
but you must have been going fast for that.....
The first thing to check is if this car has a rear window lock button as a child safety feature. These buttons are usually located somewhere on the driver's door. Sometimes you push them by mistake and then you think your windows aren't working.
The second think to check is the fuse box. Check your owner's manual for the exact location. There should also be a fuse box diagram. It's possible the the rear windows are on a separate fuse and all you'll need to do to is replace it. If it is a fuse make sure your replacement is rated at the same number of amps as the original.
the fuse box is under the hood basically behind the battery but if the power windows are workng the fuse is good.you may have a wiring problem or a bad motor
THE FUSE BOX ON 06 IS PART OF THE TIPM MODULE UNDER THE HOOD THER IS A BLACK COVER ON IT THAT SAYS POWER DIST. CENTER. THERE ARE A COUPLE OF CLIPS AND IT PULLS UP
