Question about Apple Computers & Internet
How do I reset a 10.5.8 apple laptop - Apple Computers & Internet
    New Friend:
  • 24 Answers
If frozen, power button kept pressed will force power off the device after ~5 seconds.
in case you are searching for special resets see below.
Smc reset description is here: http://support.apple.com/kb/ht3964
Pram reset description is here: http://support.apple.com/kb/ht1379
Posted on May 03, 2014
6ya staff
SOURCE:
The apple logo appeared but phonr no work
  1. How to reset
    1. You should reset your device as a last resort and only if you can't restart it.
    2. To reset, press and hold both the Sleep/Wake and Home buttons for at least 10 seconds, until you see the Apple logo.
Aug 31, 2014 | Apple iPhone 3G
Reset apple id account
Unfortunately, you will need to get to a laptop or tower PC or Mac, in order to reset your password, migrate to apple.com try to login, there should be a forgot password link just below the login entry points. The Mobile version of Apples website malfunctions when attempting to reset a password, this is why you need to go through a laptop or tower to have a successful password reset.
Aug 16, 2014 | Apple iPad 32 GB WiFi Tablet PC
I have got apple macbook pro unibody , my charger light is blinking and not charging battery while my laptop is on but when i shut down my laptop its connecting and disconnecting for 10 seconds interval
Try charging your laptop with a spare charger. If your laptop is still under warranty, make an appointment with a genius bar representative at a local Apple store to diagnose your laptop's issue and replace the charger.
Warning!
Do not use the USB ports to charge any external devices from your laptop! Instead use the chargers they were packaged with.
If the spare charger doesn't work after an hour of charging you will have to reset the System Management Controller with the Mac turned off:
Press Shift-Control-Option-Power key combination.
Release and press the power button.
If resetting the SMC doesn't work try resetting the PRAM. Keep in mind that you have to enter the key combination before the grey screen appears!
Reboot your laptop.
Immediately hold down Command-Option-P-R combination.
A reboot sound should confirm the reset.
Aug 26, 2013 | Apple MacBook Pro Laptop Computer with...
My G3 phone is flashing the apple symbol while powering up but isn't powering up.
Thank for contacting Fixya, I will be glad to assist you.
What you can do, in order to resolve this issue, is start by resetting your iPhone 3G.
(Note: this does not remove any settings, data or media you have installed in your device)
• To perform a hard reset, press and hold your Sleep and Home Menu buttons for approximately 10 seconds.
• Once your screen goes black, release both keys. (If you see a white Apple logo before you release the keys you have held the keys to long and will need to start the reset process once again)
• The next screens you should see after the black screen, is the Apple logo screen followed by the main screen.
• This hard reset process should help bring your iPhone 3G back to normal functionality.
It would also be advisable to connect your iPhone 3G via its docking cable and provided wall socket adapter into a working wall socket in order to try and charge it.
If your iPhone 3G still does not charge, try connecting it with the docking cable to your computer or laptop to observe if it will take a charge then.
Should this process also not affect the way the iPhone charges, then you should look into using or purchasing another iPhone docking cable, as the cable itself may not be functional and needs to be replaced.
Docking cables for iPhones are fairly inexpensive (Under $20) and can be found in most electronics/computer stores that carry Apple products and accessories.
(Link: Apple Dock Connector)
Finally, if a replacement docking cable does not help the iPhone 3G charge, this may be a hardware issue and you would be advised to take the iPhone 3G in to your local Apple retail store or Apple Authorized Service Provider in your area.
Regards,
-The MacTechTrainer
Aug 07, 2012 | Apple iBook G3 Mac Notebook
My Apple mac book pro will not boot up. I have a grey screen. I've taken out the battery held doen the on button for 5 seconds and re connected it nut I've still got a grey screen. Help
The grey screen is the bios of your laptop is booting, this is freezing for some reason.
Do 3 things.
Try holding power button down for longer at least 10-20 seconds.
do a PRAM reset, apple symbol, alt P & R keys all held on boot up.
Do a smc reset.
  1. Shut down the computer.
  2. Disconnect the MagSafe power adapter from the computer, if it's connected.
  3. Remove the battery.
  4. Press and hold the power button for 5 seconds.
  5. Release the power button.
  6. Reconnect the battery and MagSafe power adapter.
  7. Press the power button to turn on the computer.
Please dont forget to vote this answer was helpful
Many thanks
Feb 15, 2011 | Apple MacBook Pro Notebook
My apple 13" laptop not
I would try a SMC reset first, if that doesn't work for you, a PRAM reset might as well.
To perform a SMC reset, remove the battery from the unit, and remove th e mag safe adapter. now when there is no power going to the unit, press and hold the power button for 10 seconds. replace battery, and power and try to start the unit.
To perform a PRAM reset, turn the unit on, as soon as it turns on (before the apple logo pops up) press and hold "CMD" + "Opt"+ "P" + "R". Continue to hold until you hear the unit "chime" 3 to 4 times. then let go and see if it boots up.
Now if these help, then great, your in business, but if you leave it for a while on, and all you see is a folder with a "?", then you most likely have a dead Hard Drive.
Jan 25, 2011 | Apple 13.3 MacBook Intel Core 2 Duo...
RESET APPLE LAPTOP
You can either do a soft or hard reset. If u find no go even after the reset, You can reinstall the OS if i like to do so.
Soft reset
  • Close all applications.
  • Click on the apple in the upper left-hand corner of the screen. Select "Restart" from the menu.
  • Press restart button located on the upper right-hand corner of the keyboard. Your computer will turn back on.
  • Hard reset
  • Press the power button located in the upper right hand side of the keyboard, just above the eject button.
  • Continue to depress the button for 10 seconds. The computer will power off.
  • Press the power button again to turn your laptop back on.
  • Oct 09, 2010 | Computers & Internet
    What if the ipod classic is not responding to the laptop and it wont switch off.Reply plz
    A reset of the iPod may resolve the issue. To reset the original iPod follow these steps:
    1. Toggle hold on.
    2. Toggle hold off.
    3. Press and hold the Play/Pause and Menu buttons until the Apple/iPod logo appears, about 10 to 15 seconds.
    4. You might need to repeat the process.
    I hope the information above has helped is some way.
    Sep 05, 2010 | Apple iPod nano
    Toshiba laptop to airport extreme cannot get connection
    how old is the toshiba laptop? It might not be able to use WPA2.
    Sep 10, 2008 | Apple AirPort Extreme Router
    Open Questions:
    Computers & Internet Logo
    42 people viewed this question
    Top Apple Computers & Internet Experts
    Paul Carew
    Ekse
    Jeffrey Groves
    Jeffrey Groves
    Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
