After removing a paper jam and repairing the paper sensor, I am getting a 0xc05d0281 and 0xc052281 ink system failure message. I have tried several times to reset with ok cancel black and color. It keeps coming back.
Can you help
0xc05d0281...ink system failure. Printer is completely non functional
There may be some conflict arised in Printer, and you need to reinstall it again:
Uninstall the HP Printer software by using the Add/Remove Programs tool in Control Panel. The HP software will includes: By Printer Design Home HP Print creator HP assistance HP Instant Delivery HP Print Screen Utilities HP Photo and Imaging software
2. Uninstall the printer driver from the device manager. Please remove the USB Cable from your PC completely. Restart your PC without connecting USB cable back to your PC. Then install the HP printer software, when it ask to connect the printer, then only connect and power on. Your PC will automatically accept this USB Hardware driver. After doing above steps please reboot your PC finally and Printer
Visit the Official Web site of HP for your Printer driver and other useful information using this link:
Give your rating to the solution either Helful or Fixya.
If you dont fix the problem yet by the solution given then I would suggest you more options, let me know for it.
Since your voting is precious to me in providing the help for others.
Have a Nice day.
Regards,
Ellin
Reply please if the soluton work for you.
Have a Nice day.
Regards,
Ellin
You can't post conmments that contain an email address.
Paper jam message occurs when there are stuck papers inside the printer. There are several ways on how to correct this problem, either you remove the visible stuck paper manually or replace the toner or ink cartridge. Below are the steps you'll want to follow when this problem still occurs.
1. Turn off the printer. Turn the printer off and on to see if it can automatically clear some or all of the jam.
2. Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it. Remove any paper trays. Inspect them for wrinkled or damaged paper.
3. Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it.
4. If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
5. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
6. If the paper does tear, try rotating the roller gears manually to free the paper . Don't force anything.
7. Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
8. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path and try repeating the above steps again.
Start by following the steps below to get the paper out from the machine.
Also open the back cover of the printer if this model has one.
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do
this step especially if the jam message comes up repeatedly without any
obvious paper jam, there may be a small tear of paper inside.
Ones the printer is free of paper Replace the toner or
printer back on.
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
see alternative if the problem is still not solved.
alternative :
Load
a piece of thick paper, for example photo paper and press the resume
button (may be diffrent button on diffrent models) a few times to the
printer picks up the paper and puts it through the machine.
Advanced
If
that doesn't help then you would have to start taking apart the machine
to find the jammed paper and remove it, its not something a just anyone
should do unless you have experience.
you may have to take the
machine to a repairer to get the jammed paper bits out of the machine,
if you don't see paper jammed in the machine it does not mean that
there wouldn't be a paper jam somewhere in the unit along the paper path.
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this several times but there is no paper to clear and the message keeps coming back. I've tried turning of the printer and unplugging it to clear the memory, but that doesn't help. Could it be that the chip on the ink cartridge is messing with the printer's operating system?
printer back on.
alternative :
Load
Advanced
If
there wouldn't be a paper jam somewhere in the unit along the paper path. Some of the switches or sensors might have gotten stuck.
printer back on.
alternative :
Load
If the problem is not solved the printer would need to be taken apart and cleaned, there maybe some paper inside or something else that is not supposed to get in there.
I would recommend sending it to a repairer in that case, or contact your dealer or hp for warranty repair. This may not be covered by warranty, check with your dealer or hp.
printer back on.
alternative :
Load
printer back on.
alternative :
Load
printer back on.
alternative :
Load
have you unpluged it from the outlet? can you see any paper stuck? otherwise you have a bad system board and would cost more to fix than just to by a new one.
i have a problem with hp 6288 all in one printer
the printer will be shown massage "paper jam"
