Freezers Logo
Anonymous Posted on Dec 18, 2011
Why can't a Haier chest freezer be put in garage?
We bought a Haier chest freezer today were getting ready to put it in our garage. But the manal says "do not install your freezer in any location not properly insulated or heated e. g. garage etc. Your freezer was not desinged to operate in temperature settings below 55 F." I read about not putting freezer in garage due to high energy cost in summer. Nobody seems to have a problem in winter. Is this a special problem for this Haier model only?
  • 1 more comment
  • Anonymous Dec 18, 2011
    Thanks. If that's the case why would the manufacturer put a restriction like that?
  • ReGina Lewis Dec 18, 2011
    Even in the depths of winter, when your garage is10 degrees, your freezer is attempting to regulate the temperature inside. So keeping it out there might hurt its efficiency and cost more. I have mine in the garage and have never had a problem as long as I maintain it
  • Anonymous Dec 19, 2011
    That makes sense. We are down in Georgia and temperature in garage never goes below freezing. However I read about lower amphibian temperature may compromise the life span of the freezer and thus void the manufacturer warranty.
ReGina Lewis
Level 1:
New Friend:
  • Contributor 13 Answers
  • Posted on Dec 18, 2011
ReGina Lewis
Contributor
Level 1:
New Friend:
Answers
13
Questions
0
Helped
8985
Points
38
The only problem that you might have is with the coils and the flux capacitor. If you clean the coils, it should be fine.
2answers
Lost manual and need to defrost
This is likely a manual defrost freezer, which means you have to remove the food, unplug the unit, and let the ice melt on its own. Do not, and i repeat, DO NOT poke the ice away from the walls. I guarantee if you poke the ice away from the wall, you'll poke a hole in the wall, and force yourself to buy a new freezer.
SLOWER IS SAFER. put some boiling water, in the pot, inside the freezer, or use a hair dryer.
1helpful
Haier freezer chest not cooling. Green light is
Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
jim
1helpful
Can a chest freezer be put in an unheated garage?
yes you may encounter problems come sumer depending how hot it gets where you live but during the winter you should have no problems.
1helpful
Freezer light flashes
If its a neon lamp then the flashing might be normal
Top Haier Freezers Experts
NOEL
NOEL
Rob Hill
Rob Hill
Are you a Haier Freezer Expert? Answer questions, earn points and help others
