Just bought second hand machine, ran it empty to start with and when done brown flakes remained in the bottom of the machine, i have run it empty on hot and cold washers at least 10 times, have run the cleaning cycle 3 times and there are still flakes. am trying to take the drum apart to see if i can get to the source of the dirt, have only been able to remove the bottom of the drum, by removing the centre bolt and using a piece of wire to take out the circle base plate. am i on the right track and whats next, what other internal parts can i remove to deep clean the machine. thank you
SOURCE: when the wash cycle is complete, the inside of the
maybe it comes from the filter inside the tub.looks like a net.just clean it
SOURCE: Hi there, I have a Samsung top loader and have
Surely you are in a better position to work this out than us! Try ising a hose with a rubber cup connection to fot to your tap.Perhaps even boild up a large container of hot water and carry it to the machine!
Thanks for using FIXYA
SOURCE: I have no hot water entering the wash tub. i have
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
