Well the photos i take from my camera, have horizontal lines across it it's like there is lots of thin line in the photo ..what should i do .?.( my video is fine it;s just the photo's that have these lines )
The fact that it takes the pictures ok confirms that it's not the ccd which has failed. A CCD problem would explain the
lines on your pictures and the lines on the LCD (since the CCD is used
to feed the live image). CCD (Charge Coupled Device) is one of the two main types of image sensors used
in digital cameras.
Some
symptoms of a defective CCD
include distorted images or abnormal colors, scratchy purple lines,
blank or black pictures, and/or black videos with good sound being
recorded on the camera's flash card.
When a picture is taken, the CCD is struck by light
coming through the camera's lens. Each of the thousands or millions of
tiny pixels that make up the CCD convert this light into electrons. The
number of electrons, usually described as the pixel's accumulated
charge, is measured, then converted to a digital value. This last step
occurs outside the CCD, in a camera component called an
analog-to-digital converter.
In order to correct this issue, the repair facility needs to replace the CCD. This is not something you may do on your own; check this article for additional details: Bad CCDs. This, isn't a good new, but hope helps to solve it.
Samsung themselves wouldn't normally
bother; a warranty claim usually means they chuck your camera away and
send you a replacement. If you're in the UK click here for details of how to proceed with Samsung.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate
your time and consideration if you leave some testimonial comment about
this answer.
Thank you for using Fixya, and have a nice day
