Fender Frontman 212R 100W 2x12 Guitar Combo Amplifier Logo
AARON GERBER Posted on Mar 07, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a solid state Fender Frontman 212. After it has been on for a few min. it starts to crackle and pop. This will happen rather my guitar is plugged in or not. I have changed chords and plugged into other areas and it is the same thing. Cannot get it to do it by shaking the amp.
rhodesworks
Level 3:
Top Expert:
  • Fender Master 3,159 Answers
  • Posted on May 28, 2018
rhodesworks
Fender Master
Level 3:
Top Expert:
Answers
3159
Questions
Helped
561882
Points
331463
You have an internal component heating up and loseing contact. Take it to a Fender service center for repair.
4 Related Answers
Anonymous
  • 5 Answers
  • Posted on Aug 22, 2009
SOURCE: Fender Frontman 65R Solid State guitar amp.
There is a protection thermistor in the circuit to keep it from over-heating, this is why it works again when it cools. Check and make sure you are not covering any ventilation holes, or if the unit has a fan, make sure it is working.
Anonymous
  • 22 Answers
  • Posted on Sep 28, 2009
Check and make sure the amp is well ventilated in the back. This is where it can overheat.
Also, make sure you have a steady, clean electric current powering the amp.
Fred Yearian
  • 5603 Answers
  • Posted on Mar 29, 2010
SOURCE: I Have the fender 212 soild state amp.When I plug
You likely have a bad input jack. A VERY common thing with these. They don't like to work on the jack because one has to remove too much to replace it. Lazy shop! Sometimes the solder has just broken loose or the board pads damaged. Replace the jack anyway as they take a beating.
Find a shop willing to work on it properly and DON'T accept it back until it is fixed!
Another problem with amps can be the preamp output jack switch which fails to close leaving the amp dead... but it usually won't hum much when that happens.
HINT: Loop your instrument cord through the handle so when you trip and yank on the cord it won't break the input jack... saves a lot of jack repairs!
Fred Yearian
  • 5603 Answers
  • Posted on Feb 24, 2011
SOURCE: Will a MP3/iPod/CD player play through a Fender
The power amp input jack takes "line level" input BUT is monaural (single channel). The output of an ipod is Stereo. Hence you would have to "mix" the two channels before connecting to the Fender. Mixing does NOT mean just tying the two channels together. A minimu thing would be a passive resistive mixer consisting of a resistor from each of the IPOD channels to the common point going to the input of the Fender. Remember if you plug into the Fender power amp input you DISCONNECT the preamp and other circuits and would ONLY hear the IPOD input.
2answers
Fender Frontman 212R crackling noise
After ruling out guitar wiring or bad cables...
Try the 2nd input on the amp
also
Is it on both channels, or just one?
My Fender Frontman 65r started crackling even with nothing plugged in
This sounds like one of this nasty problems with the solder points. One of them might be faulty so sometimes there is a contact sometimes not. You could try to locate it by knocking gently with the plastic end of a screwdriver on the pcb. If vibrations cause the noise you could check all solder points optical or just resolder them. There are not too many. Also check all potentiometers! As they are mechanical parts vibration caused issues can be found here very often especially on their solder points.
Play mac through Fender Frontman amp
Simple: connect the headphones out (3.5mm jack) to the input jack of your fender (6.3 jack). By doing this you will loose one channel so you better generate a mono signal inside your computer before. Electrically this is no problem, nothing will be damaged. Turn the gain and volume knobs down and apply a signal from your Mac. Gently increase gain and volume. Et voila wonderful mono sound through a guitar amp
Will a MP3/iPod/CD player play through a Fender Frontman 65 or 212 "Power In" input jack?
2answers
I have a Fender Frontman 212r amp. The problem seems to be when I put the volume upto past 4/10 [40%] The amp gives out an awful crackling sound and power light etc flickers on and off. I have had the map...
When i turn on my 212R it turns on in drive channel. if footswith is plugged in, then it turns on in the clean channel, but after switching in drive it is impossible to switch it back in clean channel. What could be wrong? Swith position doesnt change anything and it seems like switch is OK.
Everytime I play on my Fender Frontman 212R the amp switches betweeen the overdrive and clean channels. I can't even switch between the channels on my own. It does it itself. I need help fixing this...
You don't say if you are using a footswitch or not... If you are, the switch, cables and connectors are suspect.
If you are NOT using the controller, the switch contacts on the footswitch jack in the 212 are suspect as being intermittent contacts.
If the contact is not making, the OD switch on the unit will NOT work either.
These jacks, and their contacts are JUNK and often cause problems.
Open the unit and increse the tension of the contact springs.
I cant get good distortion out of my fender frontman 212R can sombody help me with the settings
Start with everything in the 12 o' clock position. Adjust one thing at a time until it sounds good to you.
I Have the fender 212 soild state amp.When I plug my guitar in to the input.One of two things happen ethier no sound or a hum.I have had this amp in the shop .Had it returned to me and still the same...
1helpful
3answers
Fender Frontman 65R Solid State guitar amp. After a while whether playing loud or not,it cuts out. Switched on when cold,it works again with no issues at all,but it starts cutting out again when hot. Same...
Top Fender Music Experts
Sean Wright
Sean Wright
Virgil Watts
Are you a Fender Music Expert? Answer questions, earn points and help others
