Computers & Internet Logo
bradlee bennett Posted on Dec 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The seiral code for sims 2 - Computers & Internet
Anonymous
Level 3:
  • Master 1,216 Answers
  • Posted on Dec 21, 2011
Anonymous
Master
Level 3:
Answers
1216
Questions
Helped
308153
Points
3630
AN9R-FYDT-V4RH-U3HY-DY4Z
2answers
Need to know if my phone call unlock it lg gplg441gb
How to Unlock LG (most models):
1. Insert not-allowed SIM card
2. Power on the handset- phone will display "phone restricted"
3. Select "Cancel" - phone will display "phone restriction code"
4. Enter the SIM unlock code
5. Select "OK" - the handset is now successfully unlocked
Unlock Instruction for LG TU720 (SHINE) and VU
1. Power ON your phone with not allowed sim card (one that didn't come with the phone)
2. Type *#865625#
3. the phone will ask you to input the unlock code twice, just input the unlock code
4. Device is now unlocked
How to Unlock LG KG800 or TG800 Chocolate:
1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu.
2. Go to: Settings>Security>SimLock>Network
3. Select deactivate. Enter the unlock code
How to Unlock LG C2000:
1. Insert non-Cingular SIM card
2. Power on the handset - phone will display "phone restricted"
4. Enter the SIM Unlock code
How to Enter Unlock Codes on LG F2250:
1. With allowed sim card in the start menu type: 2945#*3311#.
2. Handset shows saved, then return to startup screen
3. Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK'
4. Enter your unlock code and OK.
How to Enter Unlock Codes on LG U8150:
1.
Switch ON your phone with a not allowed SIM card.
2.
Compose: 277634#*#.
3.
Go to menu "SIM Lock".
4.
How to Enter Unlock Codes on LG U8110:
1. With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*#
2. Select 'Sim Unlock' menu #
3. Enter NCK code then validate
4. Your phone is now unlocked.
How to Enter Unlock Codes on LG U8210:
1. With a not allowed sim card enter Pin code then validate, type: 277634#*#
2. Shows test menu
3. Choose sim test menu and type: 2945#*#, choose Sim Unlock menu
4. Handset shows 'Enter NCK'
5. Enter code, then hit OK.
How to Enter Unlock Codes on LG U81xx:
1. To bring up the unlock menu on the phone with a SIM card, type 2945#*88110#
2. Enter the code
In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#.
How to Enter Unlock Codes on Cingular AT&T LG CU500:
1.
Insert non-Cingular SIM card.
2.
Power on the handset. Phone will display "Invalid SmartChip"
3.
(IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN)
4.
In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5
5.
Enter the 8 digit SIM unlock code
6.
Select "OK". The handset is now successfully unlocked.
Unlock Instructions for LG KU990 (Viewty):
1. insert original sim card and turn phone on.
2. Press telephone icon at bottom of screen to bring up the phone keypad
3. Enter 2945#*990#
4. A menu will pop up, select sim unlock
5. Enter your unlock code and press ok
6. The phone will then reboot and the unlock is complete.
Unlock Instructions for LG KF600:
2. Enter 2945#*71001#
3. A menu will pop up to enter the sim unlock code
4. Enter your unlock code and press ok
5. The phone will then reboot and the unlock is complete.
Unlock Instructions for LG KF750 aka LG SECRET:
1. Insert original sim card and turn phone on.
2. Enter 2945#*750#
3. A menu will pop up, select sim unlock
Unlock Instructions for LG CU915:
1. Power ON your phone with an accepted SIM card.
2. Type *#865625#CODE
3. Press OK
How to Enter Unlock Codes on LG Incite CT810:
1.
Dial this into the LG Incite's phone menu
2.
2945#*810#
3. Press CALL.
4. It should you ask you for the code.
How to Enter Unlock Codes on LG Invision CB630:
1.
Insert an AT&T or Cingular SIM in the phone; it does not have to be an active SIM
2.
3.
*#865625#
4. Press CALL.
5. It should you ask you for the code.
How to Enter Unlock Codes on all other LG cell phones:
1.
Switch ON your phone with an allowed SIM card
2.
Then compose:
3.
2945#*5101# - (if you have a LG 510w)
4.
1945#*5101# - (if you have a LG 1200 & B1200)
5.
2945#*5221# - (if you have a LG 5200 & 52200)
6.
2945#*5301# - (if you have a LG 5300)
7.
2945#*5401# - (if you have a LG 5400)
8.
2945#*70001# - (if you have a LG 7020)
9.
2945#*7101# - (if you have a LG 7100)
10.
2945#*1201# or 2945#*70001# - (if you have a LG 1100)
11.
2945#*70001# - (if you have a LG7250T)
12.
2945#*2201# - (if you have a LG C2200)
13.
2945#*5301# - (if you have a LG T5100)
14.
2945#*3311# - (if you have a LG C3310)
15.
Go to "Menu" and then to "Settings"
16.
Then select "Security"
17.
To finish select "Network Provider" and select "Deactivate"
18.
19. If your cell phone is not listed, please follow instructions for LG C2000 above
How to Enter Unlock Codes on LG KE970 Shine:
1.
2.
Then compose: 2945#*9701#
3. Press CALL.
How to Enter Unlock Codes on CU575 / Trax and CU515
1. Put a non cingular sim in the phone ,phone says invalid smart chip
2. Now enter *#865625# then select option 1 and then again select 1 and enter your 16 digits code
How can you jailbreak a lg g800?
ow to Enter Unlock Codes on LG KB770: Insert an original simcard and turn phone on Enter sim PIN if required Enter 2945*#770# From the menu that pops up select "SIM unlock" Enter unlock code you received and press OK The phone will then reboot and the unlock is complete How to enter Unlock Codes to LG GB250 & GB220 Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG GT505: Power on your phone without SIM card Enter 2945#*505# From the menu that pops up select "SIM unlock" Enter unlock code and press OK The phone will then reboot and the unlock is complete How to Enter Unlock Codes on LG KP100: 1) Insert a not allowed SIM card 2) Press the unlock button 3) Enter the code OR 1. Insert allowed SIM. 2. Booting (Request PIN Code, PIN Code enable) 3. In Idle Screen, Input the hidden number (2945#*20001#) 4. Input the number (above), go back to the idle screen 5. Menu-4.Settings, 7.Security-6.SIMLock Code:-1.Network Unlock Code:-1.Deactivate: 6. Select "1.Deactivate:" Menu, Display pop up " SIM Lock Code:". 7. Input right Unlock code, Display pop up "Deactivate". 8. Reboot, and unlock simlock code How to Enter Unlock Codes on LG KF390 and KF390q: 1) Insert a SIM Card from the network the mobile is locked to and turn it on 2) Insert the following sequence *#865625#; 3) Select 'Unlock USIM' 4) Select 'Network Lock' 5) Insert the unlock code 6) Reinsert the unlock code 7) Select OK. Done! How to Enter Unlock Codes on LG Prada (e.g KE850, etc): 1. Switch the telephone on with Original SIM card inside. 2. Enter SIM pin if required. 3. Enter 2945#*8501# and press the call button (middle button bottom of the screen). 4. SIM unlock mode will appear on screen. 5. Enter unlock code 6. Select Reboot. 7. Switch phone off, and then turn back on again. Phone is now unlocked How to Enter Unlock Codes on LG KE990 / KU990 Viewty: 1. Insert original sim card and turn phone on. 2. Press telephone icon at bottom of screen to bring up the phone keypad Enter 2945#*990# 3. A menu will pop up, select sim unlock: 4. Another menu will appear, select Network lock. Enter your unlock code and press ok 5. The phone will then reboot and the unlock is complete. How to Enter Unlock Codes on LG KG245 (Vodafone Australia): 1. Insert a Vodafone Australia working SIM card. 2. Ensure the phone is charged and then switch the phone on. 3. Optional Step: If the SIM card has a PIN, enter your PIN number 4. Wait for the phone to power up then enter 2945#*7101# 5. Select Menu , then go to Settings > Security > SIM Lock > Network 6. Select Deactivate and enter the 8-digit unlocking code provide for your handset. 7. The handset will be unlocked automatically and will display "Done". This will be confirmed if you can make and receive calls with the Non-Vodafone Australia SIM card. (You will need reception and phone credit with the different network provider) How to Enter Unlock Codes on LG KG800 or TG800 Chocolate: 1. With the phone in standby, enter 2945#*7101#. This will activate the extra menu. 2. Go to: Settings>Security>SimLock>Network 3. Select deactivate. Enter the unlock code How to Enter Unlock Codes on LG C2000: 1. Insert non-Cingular SIM card 2. Power on the handset - phone will display "phone restricted" 3. Select "Cancel" - phone will display "phone restriction code" 4. Enter the SIM Unlock code 5. Select "OK" - the handset is now successfully unlocked How to Enter Unlock Codes on LG U8150: 1. Switch ON your phone with a not allowed SIM card. 2. Compose: 277634#*#. 3. Go to menu "SIM Lock". 4. Enter the unlock code How to Enter Unlock Codes on LG INCITE CT810 Power on phone with original SIM card Type 2945#*810# In the menu that appears select Sim unlock Enter supplied unlock code Your phone is unlocked How to Enter Unlock Codes on LG F2250 Power on phone with Orange SIM card inserted While in the Start menu type 2945#*3311# Return to the startup screen Press Menu key Select Settings > Security
How to fix service code #u1097 on a 2005 fxsti
My manual is for a 2008 FLHRC, but it might be close enough for you.
U1097 is "Loss of Speedometer Serial Data"
The fixes are:
Check for loose/broken wire (light green/violet) between terminal 2 of speedometer and terminal 5 of ECM
If not the problem, replace speedometer.
2answers
HALLO ,I HAVE PROBLEM WITH MY MERCEDES BENZ E CLASS 280 VIN CODE IS wdb2100631a448256 PLEASE SAY TO ME FACTORY RADIO CODE WHAT IS?
they way i always do it is remove the radio get the seiral # off the radio then call the dealer and with the serial # they can give you the code,the only way to get code with vin# is if they have the code on file from repairs done in the past,
Unlocking nokia n73
give me a seiral number i want to access my phone lcok
Unlocking security code
i want nokia 6270 unlock code
seiral no 357576003338470
Grand Canyon Tech
Grand Canyon Tech
