I set off the security alarm on my car & I've gone back & forth between the door & ignition key not knowing which is which. Security light has stayed on & either doesn't run long or won't start up. I've been told I need a new ignition & key but I think I just need to reset the security.
SOURCE: wheres the fuel pump relay for my 1990 pontiac
Under the hood fuse box left side (driver side)
SOURCE: How do I reset the anti-theft system on my 2000
disconnect the negative battery cable for about three minutes, replace, put key in ignition and turn it on, DO NOT START CAR, turn it off, remove key, reinsert key and start car
SOURCE: where is the fuel pump relay on a 1990 pontiac
should be in the relay box under hood. If not, please get back to me and I'll track it down.
SOURCE: 1990 pontiac bonneville no spark what to check for
the common failure is the crankshaft position sensor.
SOURCE: 2002 pontiac bonneville interior lights
Look for a short in that circuit.Their is a hot wire grounding out
Also I put together the remote to the car & tried it & nothing happened. but maybe it messed something up? what I mentioned in my 1st comment happened the past 2 days. the remote incident that I just mentioned, happened the day of.
