Question about Hitachi Hammering
OIL FOR JACKHAMMERS - Hitachi Hammering
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 39 Answers
There is a sight glass on the side for you to see the oil level. Make sure they are always checked. You can buy the oil at any service center. Hilti makes oil too and can probably be purchased at Home Depots. Also the Home Depots that have tool rental programs would most likely sell the Hitachi oil too.
Posted on Apr 24, 2012
6ya staff
SOURCE:
How do i fix oil leak in seals of jackhammer
by a service kit that are made for your model
I do you a suggestion how you can do it yourself if you have a burner to heat up the bolts because of loctite sealant i think you know something of forces on that parts ? because of the tools that are neccesary to service it .
Here is a suggestion of a brand that is maybe there or coming in your Country . thats why i do this suggestion by a dutch link .
https://devs.hitachi-koki.co.jp/ois/explodedDiagram.html?type=svg&modelName=H+90SE&newwindow=true
If you know the brand of your hammer ? sometimes bought secondhand and no modelname google it on 3 words powertools the brand service or choose pictures if you will see pictures where you can see your hammer but there are can be marketing technical differences by the models because a suggestion i made by Hitachi the H90 and H90SE are not compatible by service kit a part of spares can only be used.
The time you spend is meaningless if you only think its leaking oil. because there is a thin lubrication inside most jackhammers and if that's leaking ,the working hours are on it, for time wasted re prematurely burned grommets make high-priority work bolt seal the front of the machine at the stroke chisel the first rings oil seals as well as the size of the stroke bolt must be tight and smooth, as if only a little air leaks burned den all your new o-rings (ie be hard in the short term) by overheating, use lubricants, not just fat because of the high temperature internal structure and the thermal conductivity of the parts together.
Jan 13, 2015 | Hammering
Wh a t type of oil do I use on a H65 hittachi jackhammer
Is not enough this is a better suggestion for you because of wasting time for only oil (lubrication is not only very importand because of heating but if it was leaking theres more to do 323745 service kit comes complete with the most neccesary parts allways but priority in this is extra (in most cases) change the strokebolt(second hammer) allways by if that looks not smooth surface.
https://devs.hitachi-koki.co.jp/ois/explodedDiagram.html?type=svg&modelName=H+65SB2&newwindow=true
Dec 10, 2014 | Hammering
Jackhammer wont hammer
A complete service kit is neccesary its pointless only to change oil, including hardened o-rings and gaskets and oil seals etc. have had their working hours. it all rests on a marketing technical calculation where no user is slicing.
look for your model and a spare parts servicekit and if the neccesary tools are present you can do it on your own. the front second hammer (stroke bolt) must be air-tight the heavy battle piece must be pulled up by vacuum by the stroke cylinder and worn rings on it and everywhere and bad seals will not succeed
Oct 25, 2014 | Hammering
Ihave a hitatchi jackhammer that operates but does not hammer, what would this be? i am not sure of the model number but i can confirm it does not have an oil level sightglass.
sounds like the connecting rod the attaches the piston to the motor is broken..They are made out of plastic and they break from time to time if you lean on your machine to much!
Aug 06, 2014 | Hammering
Jack hammer truble shooting
Replace O-Rings?
I’m happy to help further over the phone at https://www.6ya.com/expert/jason_60e0f57ba319f3f6
May 09, 2014 | Electric Demolition Jackhammer
Mtx jackhammers older set 12" one has blown voice
i want cercrit digram nissan car set rm-w50sam-k
Sep 27, 2013 | Car Audio & Video
Hammer runs but bit does not move much
how much oil do i put in my bosch jackhammer?
Jan 30, 2011 | Electric Demolition Jackhammer
I have a old electric 120vac jackhammer (not sure manf.)
usally their is grease packed in the hammer part,you can usally see a plastic type bung(plug)on outter casing
May 13, 2009 | Electric Demolition Jackhammer
Hammering Logo
998 people viewed this question
Top Hitachi Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
ray gallant
Are you a Hitachi Hammering Expert? Answer questions, earn points and help others
