SOURCE: dush washer stop working.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%^^&*(
SOURCE: WE HAVE A MAYTAG PLUS
Try holding down the drain button for about 5 seconds.
If that still does not do it for you, try taking power from the machine to let it reset itself, easiest is to unplug the unit or flip the breaker switch for the section of the kitchen. Leave it off for at least 30 seconds to let the machine reset the computer.
If that still does not do it, then you may have something that's clogged into the drain line of the dishwasher and it needs to be removed before the drain can open or close. Service would be required for it.
SOURCE: How can I get my lock on light off and turn my
If the model number is correct, press and hold the "NO HEAT DRY" button for 4 seconds to lock or unlock the controls.
SOURCE: dish washer doesn't fill up
Their are a few things that will prevent it from filling
Good luck,i hope this helps
Gene
Testimonial: "thank you for the very useful advice."
Hi
If clean light is blinking then it may be an
issue with heater circuit, door switch or wash pump, please reset the power to
the dishwasher. After, 5 minutes check if you are still getting the same error.
If yes, then it is a water heating fault. To resolve this error try pressing
this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air
Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub,
energy saver dry. Now let the unit run for 2-3 minutes and then you press
the Cancel/Drain button and allow it to completely drain and reset. If this
doesn't work then it's an issue with the wash pump not pumping the water past
the heater efficiently or due to lack of water to heat. Please make sure that
heater is not open circuited and is heating the water efficiently. You'll have
to check the heater using a multimeter; the meter should read between 3000 to
3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure
water pressure is optimum and fill valve is working fine. Hope this helps...
Please post back if you need more information.
Daniel
