After powering it up & plug in piano cable in input jack of any of the 3 channels, as I raised the master volume to about 3/4 of the way. amps starts to produce a loud crackling noise and the sounds cuts off for a while. The after a few minutes the sound comes back all distorted and cutting off.
SOURCE: wiring problem on kb 300
You have probably bypassed the crossover that directs different frequencies to the appropriate speaker/horn.
The speakers are designed to be used the way they were delivered. It is easy to damage them when connected wrong.
I would suggest you restore the circuit to the way it was designed to avoid damage to speakers or the amp.
Testimonial: "thanks for advice but havent bypassed the crossover if u have any ideas on how to split the amp from speakers would be greatly appreciated"
SOURCE: Volume low when exporting recording. If I raise
Try inserting a limiter as the last step in the process, this will ensure a better level before mix down.
