If this is under warranty take it back. If it isn't power the unit on with just the battery powering the unit. When you see the Windows splash screen drop the battery out after the screen goes black put the battery back in and press the power button. This should bring up the on screen menu telling you it failed to start or shut down correctly. Select, Boot in Safe Mode and see if the system will power on. If that fails you need to do a system restore. To access system restore options power the unit on and press and hold the F10 key, this will bring up the restore Windows options. From that menu select to restore your operating system. If that fails you will have to do a complete restore to factory default settings. If that fails you will have to replace the hard drive.
SOURCE: my coby tablet won't open
Hi s112ronnie,
If your Coby tablet suddenly has no response or powers off, an elec-trostatic discharge may be the cause. In this circumstance, please follow these procedures for recovery:
1.Reset the player (use a paper clip to gently press the Reset button (on the bottom of the player).
2.Turn on the unit again
NOTE: Back up your data to an external source prior to performing reset.
Hope it helps.
Thank you for using FixYa.
it wont pass the welcome screen
